Question about Whirlpool Dryers
How do i reconnect the heating element wires? when I removed the element, I forgot to log down the wire placement.
  • 1,998 Answers
Depending on what your model number is there are a couple of styles here is one in this video that shows how the wires are connected http://www.youtube.com/watch?v=4yZ6b5erDsw
here is another video of another type of whirlpool as well http://www.youtube.com/watch?v=eLVEl4VTNw0 and lastly here is an upclose on how to install the heater wires in this video as well http://www.youtube.com/watch?v=KZY9CQ_CqvY if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks I await your reply
Rick
Posted on Apr 06, 2011
2 Suggested Answers
  • 2468 Answers
SOURCE: how do i reconnect the
if there are only 2 wires to the element box terminal it doesn't matter which wire goes on which terminal,because its a.c. current
My defy oven's bottom element heat up although the oven is turned off
Assuming you have not removed or reconnected any of the wires I would look at the thermostat.
Nov 23, 2014 | Ovens
How do u remove the 2 wires from the heater element?
disconnect power before doing anything. in the case of no convenient means of disconnecting the wire, i see no problems with cutting the wires and reconnecting using butt splices for the proper guage wire. place your splices strategically so that they are easy to reach but out of the way of any excessive heat or moving parts. you probably should wrap the spices with electrical tape to avoid a short circuit and always work with the power disconnected. i have used this method many times on many applications with no problems.
Jun 04, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
How do i reconnect the heating element wires on a whirlpool dryer ler4634jq0? i forgot to log the wire placement when removing the heating element. Help!
Apr 06, 2011 | Dryers
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
Need instructions for replacing the heating element
First UNPLUG UNIT remove the 7 or 8 screws securing the back to the dryer,the heating element is on the lower right ride where the wires are going. 2 screws hold the element in position. You will need to transfer the high limit thermostat to the new element, reinstall and reconnect all wiring, reinstall back ...Now enjoy the fact that you fixed it yourself and saved some cash as well... Good luck
Aug 15, 2010 | Whirlpool WED5300S Electric Dryer
We lost the wiring diagram for the dryer and removed the heating element from it to get a new one. Now we can not seem to install in right because of wire placement any help would be appreciated. it is a...
From what I can tell you should be only dealing with two wires. The element should be slid, coils up, into the metal sleeve in the bottom right and the wires should connect to the prongs. If your wires arent reaching then you may need to splice some more wire in or replace the wire with a longer one.
Dec 12, 2009 | Whirlpool Dryers
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
My dryer works properply but doesn't heat
Disconnect power . Remove the panel from rear of dryer . On the long aluminum housing , close to the top , will be a small thermostat piece . Either check this piece for continuity or jump those 2 wires togather and reconnect the power . Check to see if dryer heats . If heats , pt # 279816 is the part you need . Both parts in the kit , must be replaced . If the dryer does not heat , disconnect power , reconnect the wires and check the element with an ohm meter . The wires for the element , are the 2 wires at the bottom of the housing . If no continuity , pt # 279838 is the element number .
Sep 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer does not heat and continues to run/will not shut itself off
This is probably due to a faulty heating element, something the average do-it-yourselfer can replace. Disconnect the power supply, then refer to the owner's manual for procedures to remove the front panel from your specific model. If your dryer has a toe-kick plate in front, that's all that needs to be removed.
1)Locate the heating element heat shield, a box on the lower right side of the dryer.
2)Using a screwdriver, pull the two screws at the front of the heat shield. Remove the front of the heat shield or, if it is on a hinge, flip it down.
3)Remove the wire leads from the heating element terminals by pulling on the leads. To avoid damaging the wires, do not grab them when you pull off the leads.
4)Remove the holding screw on the side of the heat shield that connects to the heating element.
5)Remove the heating element by sliding it out of the heat-shield box. Install a new heating element and secure it to the heat shield with the holding screw on the side.
6)Reconnect the wire leads to the new heating element by pushing them onto the terminals. Place the heat shield front cover back into position and secure it with the mounting screws.
7)Replace the front panel or toe-kick plate and reconnect the power supply to the dryer.
Aug 28, 2009 | Frigidaire Dryers
HOW TO REPLACE HEATING ELEMENT
Turn off the electric panel breaker that powers the unit! Check to make certain it is off before proceeding.
You will need to disconnect the Dishwasher (DW) from the electric, water and drain lines and remove it from under the counter in order to be able to access the underside of the DW. There you will find two (2) wires connected to the heating element along with a couple of fasteners that hold it in place. Also check inside the DW for any hold down clamps, etc. on the heating element there.
Once you have removed the connectors and mounting screws, you can then remove the element from the inside of the DW. You will need to "pop" out the grommets that the element passes through from the inside to the underside of the DW, as these keep water from leaking past the elements. Just remove and save those grommets and reinstall them onto the new element and slip it back inside the DW and through the holes in the floor of the unit. Reconnect the wires and re-fasten the screws or clamps that hold the element in place and reinstall the DW back under the counter, reconnecting the water and drain lines and the electric power.
This is a fairly simple and money saving repair for the DIY'er and well worth the time it will take you to perform the replacement. Good luck and hope this helps. Here's a link to the versions of your DW that will show you what it looks like for the parts and placement for your specific unit as I couldn't locate an exact match without the rest of the model number series. Just select yours and look at the diagrams to find the heating element on the inside of the wash tub.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GU980SCG&pop=flush
Jul 28, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Dryers Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
