Question about HP LaserJet P4015N Printer
On the top screen of the printer it is showing Checking paper path, then at the bottom of the screen in a rectangle box it says Some pages may be ejected. Printer will not print.
SOURCE: Printer keeps saying change paper size
Make sure the paper size on the pinter matches the paper size in printing preferences of your computer. I had the printer set to Letter, but the paper size in the driver after I installed it was A4. After I set it to Letter in the printing preferences the problem seemed to be solved.
I did it in 2 places:
When I printed from internet explorer, I clicked printing options
I also right clicked on the printer icon and modified it in printing options
I hope this helps
Posted on Jan 26, 2008
pagebor
  • 2785 Answers
SOURCE: Paper feed accepts paper but
your printer needs servicing
Posted on Apr 23, 2008
  • 3422 Answers
SOURCE: HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Posted on Jul 05, 2008
SOURCE: Black smudge on side of paper when printing quanities
I've found these smudges to be caused by a build up of toner on the edge of the drum. Carefull cleaning with a lint free cloth sometimes cures the problem.
This model also has a transfer belt, that could also be the cause of the problem.
Posted on Jan 08, 2009
SOURCE: HP PSC1410 wont print and shows offline
I had the same problem. This is what worked for me: I went to the HP website and downloaded the hp Print Diagnostic Utility. Found the problem and fixed it in no time (device manager I believe)... worked beautifully. Hope this helps :-)
Posted on May 20, 2009
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
Apr 07, 2015 | Lexmark E238 Laser Printer
Canon i3235
Are the lines across the page, in the direction of text, or from top to bottom. If from top to bottom, watch the scanner bar with the cover up, see if anything looks odd. If the paper moves in this machine, like from an auto feeder, it could pick up a streak from something in the path.
Checking, this unit is a laser printer. When replacing toner, there usually is a little tab thingy that is supposed to be moved back and forth over a little wire. The wire must be kept clean, too. Also, there may be a white bar with a glass cover that is to be cleaned very carefully every time toner is changed. Find this piece of glass, a speck of dust is probably your culprit.
Nov 26, 2013 | Office Equipment & Supplies
The screen just show "paper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Feb 16, 2011 | Canon MX300 Office All-In-One Printer
How to print 2pages on one sheet of paper (side by
press key with windows logo(bottom of keyboard, both sides of spacebar),choice printers and faxes,find printer your using(if you have more than one listed, or the one with check by it),double click, when document box opens,click on printer(upper left at top of box),under page layout choose # of pages per sheet...2 will give you 2 pages side by side,4 will split the sheet into 4 quarters.
Mar 20, 2010 | HP Officejet Pro L7680 All-In-One Printer
How do you load document to send fax. With letter facing you or facing down. Model HP 920
There should be an icon on the device showing a rectangle and what appears to be a triangle on top of it. This is showing you a folded page. If there are no lines on the rectangle with lines on the triangle then you insert the page face down (print on page towards the device) if the rectangle has the lines and the triangle doesn't, you insert face up (print facing you while in the inserting into the machine)
If you have any more concerns address your owners manual, this can usually be found on a CD that came with your printer or at HP's support website.
Let us know if you have any other issues.
Apr 16, 2009 | HP 920 Plain Paper Fax
Paper jam in my new Lexmark x2600 inkjet printer
Here's how to clear printer paper jam.
  1. Pull the paper out if it is visible. If not, then open the top of the printer so that the jammed piece of paper is visible.
  2. Grasp the paper and pull gently but firmly. If the paper continues to jam in the printer, inspect the rollers to ensure that they are grabbing the paper and pulling it along the paper path properly.
  3. Check the paper path for any obstructions, and clear if found. Also, inspect the other parts that the paper travels through, to ensure that they are not dirty or gummy. If any dirt or other debris is found, clean the parts and try again.
  4. Close the top of the printer.
  5. Place the printer back online. Try the print job again.
Just let me know for further assistant.
pincer
Apr 07, 2009 | Lexmark X2600 InkJet Printer
No bottom page border
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
Printing invitations
if you are printing from word 2010 and have an HP printer;
-set up your document on your screen how you want it to look, go into your print preview section, your printer should be listed towards the top of your page and directly under it should be "printer properties" click here, select the features tab in the next window and change your paper size to the correct size for your document.
-you may also need to go into the page layout tab in the main screen, select the size button, click on "more paper sizes" at the bottom of the window, select the paper tab and change the size of your paper again to the size of your document
-lastly, while in the "paper" tab window select "print options" towards the bottom right corner, left side of new screen click on advanced, scroll down to print and make sure there is NOT a check in the box that says "scale content for A4 or 8.5 x 11" paper sizes
Jan 22, 2009 | HP Officejet 6310 All-In-One InkJet...
Unable to configure the HP C6380 for double-sided printing
Here is the step by step right from the user manual. also here is a direct link to the manual.
http://h10032.www1.hp.com/ctg/Manual/c01527492.pdf
Let me know how it works out for you.
Print on both sides of the page
You can print two-sided pages with the HP All-in-One manually. When printing two-sided
pages, make sure to use paper that is thick enough so that images do not show through
to the other side.
To print on both sides of the page
1.
Load paper into the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the product is the selected printer.
4. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Click the Features tab.
6. In the Paper saving options area, select Manual from the Two-sided printing dropdown
list.
Perform special print jobs 83
Print
7.
For binding, do one of the following:
• For binding on the top like a notebook or calendar, select the Flip Pages Up check
box.
This causes the odd and even pages of your document to print opposite of each
other top-to-bottom. This ensures that the top of the page is always at the top of
the sheet when you flip the pages up in your bound document.
• For binding on the side like a book or magazine, click to clear the Flip Pages
Up
check box.
other left-to-right. This ensures that the top of the page is always at the top of the
sheet when you turn the pages in your bound document.
3 5 1
8. Click OK, and then click Print or OK in the Print dialog box.
The product begins printing. Wait until all the odd-numbered pages are printed before
removing any of the printed pages from the output tray.
A dialog box displays instructions on the screen when it is time to process the second
side of your job.
9. Click Continue when done.
Nov 28, 2008 | HP Office Equipment & Supplies
Printer shows color cartridge m/t
Have you replaced with original HP cartridges? HP mark is well known for sensitivity to non-original cartridges.
Jan 25, 2018 | HP PhotoSmart C3140 All-In-One InkJet...
HP LaserJet P4015N Printer Logo
211 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
