Question about HP Office Equipment & Supplies
Paper Jam in HP Deskjet F2100 All in One - HP Office Equipment & Supplies
    Novelist:
  • 180 Answers
1. Check for and remove any paper stuck in the paper in tray
2. clear the paper jam from the back of the printer
a. unplug the AIO
b. Press in the tab on the left side of the rear door to release the door. remove the door by pulling it away from the AIO
c. gently pull the paper out fo the rollers
d. clean the rollers with a lint free cloth that is moist with distilled water
3. Lift the front cover and slowly remove any jammed paper
a. unplug the power cable
b. if necessary pull the input tray down to open it. then lower the print cartridge door
c. gently pull the paper out of the rollers
d. close the print cartridge door
e. plug the power cable
4. Verify that the print cartridge carriage can move freely
b. check to see if the print cartridge carriage can move freely from one side to the other.
c. remove the print cartridges
d. gently move the print cartridge to tyhe far right of the printer
e. remove the paper from the paper in tray, but do not remove the drawer
f. remove the rear acces door
g. with your fingers rotate the rollers "up" three full rotations
h. close the rear access door
i. replace the print cartridges
j. plug the power cable
k. turn the power on
5. reload and test the printer
Posted on Aug 07, 2008
6ya staff
SOURCE:
Jose Ramirez
  • 263 Answers
SOURCE: deskjet f2100 series
what kind of software did you use or did you just install the printer with the computer drivers i need more info about this problem
Posted on Jan 05, 2008
Anonymous
SOURCE: paper jam in hp deskjet 5900 series. how do i correct?
hp 5900 printing report after print
Posted on Apr 20, 2009
Anonymous
  • 86 Answers
SOURCE: paper jam in hp deskjet d2560
Most printers have an access panel located in the back of the printer that will allow access for removal of all of the paper. Remove any larger pieces by pulling slowly and gently on the paper.
Posted on Apr 25, 2009
Anonymous
  • 14 Answers
SOURCE: paper jam in HP deskjet 380 series
I just completely took apart my front feeder unit because I just didn't believe there was a paper stuck in there. Sure enough, when I got to the bottom (an hour later) there it was- and it wasn't from the paper that was jammed. It must have been floating around in there waiting to get in just the right place to block the little sensor wiggly thing.
After I got it out, I realized there was a MUCH easier solution--- get some heavy paper (I used cardboard folded in half) and manually feed it through the paper feeder in the front assembly by hand. You can see where it should go in (it's where the paper from Tray 1 goes in) and out (it lines up with the belt in the main body of the printer) and there is a large gear on the side you can turn to help you get it through (just turn the gears until you feel the one that grabs your heavy paper.)
As it comes out, it should have your stuck paper with it.
Jeremy
Posted on Jun 15, 2009
Anonymous
  • 136 Answers
SOURCE: Why won't my HP Deskjet F2100 scan a image?
Try scanning from your PC, if you have a program that will allow it... if you have Word '97, you can do it like this:
  1. With your scanner ready and the image on the scanner glass, in Clip Organizer, on the File menu, point to Add Clips to Organizer, and then click From Scanner or Camera.
  2. In the Insert Picture from Scanner or Camera dialog box, under Device, select the scanner.
  3. Click Insert. The new clip appears in the My Collections folder, in a folder named after your scanner
If you do not have Word '97, but a program that SHOULD work but doesn't have the correct driver, go to www.twain.org for the latest twain-compliant drivers for your scanner! You may also be able to find a simple scanning app (in the downloads section) at www.cnet.com
Hope this helps!
-- RT
Posted on Sep 03, 2009
HP Printer deskjet f2100 driver for win 8
You dont have drivers for Deskjet F2100. You need to connect the printer via USB cable and the printer will be ready to print. To SCan a file, you need to use paintbrush or any other image application tool.
Regards,
Sean
May 29, 2013 | HP PSC 1610 All-In-One InkJet Printer
Paper jam
check if there is any piece of paper is jamed inside your printer i think that is why your printer always says paper jam
Jul 08, 2010 | HP DeskJet F380 All-In-One Printer
Hp deskjet d2360 paper jam
dear sir
I miss my Driver CD so I want this Deskjet D2360 Driver
Jan 19, 2009 | HP Deskjet D2360 InkJet Printer
Hp deskjet F2100 series
how do I clear a Printer HP deskjet F2100 series.? As it doesnt come out very well.
Nov 02, 2008 | Office Equipment & Supplies
Hp deskjet 5150 paper jam
u have to need to do change the printer roller
Sep 01, 2008 | HP DeskJet 5150 InkJet Printer
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
Can't install software for HP Deskjet F2100
I DONT HAVE CD FOR MI HP DESKJET F2100 HAW I CANT INSTAL DRIVERS
Jul 18, 2008 | HP Office Equipment & Supplies
Paper jam in HP Deskjet F2100 all-in-one. Flashing light indicates trouble with cartridges 21 22, but can't get at them because they are stuck at sides. Cartridges newly installed.
Thank you. Problem solved. Original cause was my inexperience: learning new tricks at age 88 isn't easy. I simply manhandled the paper jam and it worked.
Jul 03, 2008 | HP Office Equipment & Supplies
Hp deskjet f2100 problem
I have down loaded a HP Deskjet All in one F2100 to my computer The printer is working but not the scanner can you help me
Nov 12, 2007 | HP PSC 1610 All-In-One InkJet Printer
Open Questions:
465 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
