Question about ASUS ENGTX580/2DI/1536MD5 - Graphics adapter - GF GTX 580 - PCI Express 2 0 x16 - 1 5 GB GDDR5 - DVI PCI Express Video Card
I have just installed an ASUS ENGTX580 DCII/2DIS/1536MD5 graphics card in my new build system. The fans spin, lights come on on the circuit board but no video output on either VGA or DVI-D (tried on 2 diferent monitors). What's the problem please?
  • alexander953 Apr 06, 2011
    Thanks - the change in bios settings fixed the problem
    Genius:
  • 1,400 Answers
Hello
First try changing from onboard sound to pci ex in the pc bios.hit del or f 12 key while booting up.
Once in the bios change graphic settings from onboard to pci.Then reboot.
Next...Drivers have you loaded both your motherboard chipset drivers and the video card drivers?
Try reseating the card.Take out the card and reseat,possible card is not in correctly or seated all the way.
Verify you have a good monitor cable and no pins are bent.Dont use dvi settings if your doing gaming you will be dissapointed.
Posted on Apr 06, 2011
  • mpcheesman1
    mpcheesman1 Apr 06, 2011
    Im sorry change the onboard video, not sound in the pc bios.
  • mpcheesman1
    Sorry not onboard sound,i ment to say graphics.
Hello everyone. Just wondering do I need an optical drive for my brand new pic I just built? And I just installed my motherboard and the graphics card together but nothing is working on the screen.
use the cd that came with the mother board as it has all the drivers to make the mother board work and to line up the graphic card
if the was a cd for the card run that as well
other than that talk to a IT geek shop and get ideas
Sep 14, 2015 | ASUS Computers & Internet
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
Black screen problem
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Pavle Suboti.
Your computer is overheating and is shutting the video off to prevent damage. It is most likely the graphics card that is suffering from too much heat. Clean the card of dust if present.
Also it is important to install lots of 120mm fans in modern computer systems to expell heat and introduce freash cool air from outside the case into the system.
Use a program called MSI Afterburner to adjust fan speed to a set heat vs fan speed curve. This allows one to set fan speed higher for high tempreatures. For a cool graphics card.
Leave the program open to see how hot your graphics card gets.
Chat to gaming friends or google to learn how to use MSI Afterburner effectively.
A cool systems is a happy system.
Take care!
Apr 15, 2012 | ASUS Video Card EAH6850 DC/2DIS/1GD5...
My d530 minitower powers off unexpectedly and red lights starts to blink on System's LED//
Hi Kindly let me know how many times the red light blinks
Condition Code Service Actions Processor thermal protection activated. Power LED blinks red twice, once a second, followed by a two second pause.
  1. Make sure the computer air vents are not blocked and that the cooling fan is running.
  2. Open the hood, press the power button, and see if the processor fan spins. If the fan is not spinning, make sure the fan cable is plugged into the cable header on the system board, and that the fan is properly installed and seated.
  3. If the fan is plugged in and seated properly, but is still not spinning, replace the processor fan.
  4. Reseat the processor heatsink and make sure the fan assembly is attached to the heatsink properly.
Processor is not installed. Power LED blinks red three times, once a second, followed by a two second pause.
NOTE: This condition indicates a missing or improperly installed processor, not a defective one.
Make sure there is a processor in the system. Reseat the processor and verify that it is installed properly. Power failure (power supply is overloaded) Power LED blinks red four times, once a second, followed by a two second pause.
  1. Check the voltage selector, located on the rear of the power supply, is set to the correct voltage (the correct setting depends on the region).
  2. Open the hood and make sure the 4-wire power supply cable is fully connected to the power connector on the system board.
  3. Check if a device is causing the problem by removing all attached devices (such as disk drives and expansion cards), then power on the system. If the system enters POST, power off and replace one device at a time, repeating the procedure until the system power failure reoccurs. Replace the device that caused the failure, then replace each of the other devices and confirm that they are functioning properly.
  4. If you cannot isolate the failure to a specific device in the previous step, replace the power supply. **
  5. Replace the system board.*
Pre-video memory error. Power LED blinks red five times, once a second, followed by a two second pause, and five simultaneous beeps are sounded
  1. Reseat the DIMMs in the memory slots on the system board, then power on the system.
  2. Replace the DIMMs one at a time to isolate the faulty module.
  3. Replace 3rd-party memory with HP memory.
  4. Replace the system board.*
Pre-video graphics error. Power LED blinks red six times, once every second, followed by a two second pause, and six simultaneous beeps are sounded. For systems with a graphic card:
  1. Reseat the graphics card and then power on the system.
  2. Replace the graphics card.
  3. Replace the system board.*
For systems with integrated (on-board) graphics, replace the system board. PCA (system board) failure. ROM detected failure prior to video. Power LED blinks red seven times, once a second, followed by a two second pause, and seven simultaneous beeps are sounded. Replace the system board. Invalid ROM based on bad checksum Power LED blinks red eight times, once a second, followed by a two second pause, and eight simultaneous beeps are sounded.
  1. Reflash the ROM using a ROMPaq diskette.
  2. Replace the system board.*
System does not power on. No beeps or blinks since the system is not functioning. Press and hold the power button for less than four seconds. Perform the following steps depending on whether the hard drive LED turns green.
If the hard drive LED turns green, then:
  1. Make sure the voltage selector (which is located on the back of the power supply) is set to the correct voltage for your region.
  2. Remove the expansion cards one at a time until the 3.3V auxiliary light on the system board turns on. If removing a card turns the light on, replace the card and then see if the system works.
If the hard drive LED does not turn green, then:
  1. Make sure the computer is plugged into a functioning AC power outlet.
  2. Open the hood and make sure the power button is securely fastened in the power harness and that the harness is connected properly to the power connector on the system board. In other words, make sure that the power button is making contact with the power circuit.
  3. Make sure the power supply cables are connected properly to the power connectors on the system board.
  4. Check to see if the 3.3V auxiliary light on the system board is not turned on, replace the power supply. **
Dec 29, 2009 | HP Compaq d530 Convertible Minitower PC...
My ASUS P5SD2-VM Is Having A No Display Problem
Make sure you disabled th eonboard video card. Some boards do it for you automatically when you install a new one and others you must remove or switch a jumper pin on the motherboard. Consult your manual for the jumper location. Sometimes you have to use the default card and go into the bios set up and disable it in there, shut down the system install the card then restart using the new card. Make sure you use the first available PCI-e slot closest to the CPU and you should be all set.If not your card may be bad.
Joe
May 28, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
Pci express slot
Hi dineshcs.
When adding a new graphics card (Your's being a PCI-Express), you must change a bios setting under the title " Advanced " section. Open you're M2N-MX manual & turn to page 2-21. You need to change the boot order for you're graphics to list,
[PEG/PCI]. Change Initiate Graphic Mode Select to [Disable].
These changes stop the onboard graphics card from loading & allow the PCI-Express card to load. The issue of possible motherboard overheating can be caused by many things. Here is a list of things to check.
1). Check the CPU heat-sink fan. Make sure the fan blades are
free from dust build up. Check fan speed in bios (Its RPM will be listed). It should be running a min of 2300 RPM.
2). Also in the bios is Hardware monitor. By booting into the bios go to this & watch the temp of CPU & motherboard. If either is getting too hot suggest you add a side case 3" fan to the system to help lower the CPU & motherboard temp.
Good Luck!
Mike
Jul 18, 2008 | ASUS M2N-MX Motherboard
Motherboard problem
1)first u check by single ram, if not
2)remove the graphic card and connect moniter to onboard VGA, if done
3)refer the manual and select the jumper pins as master for AGP ,now connect to graphic card
4)if no display
5)remove the graphic card and try in on board vga
6)now you cant get display remove the bios battery and clear the cmos by using jumper pin short (refer mother board board manual ).then try with both VGA output
(NOTE:-if AGP or PCIE card present on board VGA not functoning)
all the best keep trying -i hope you get working pc by half an hour,if not call to profesional servicemens
regards
prasanna
Mar 06, 2008 | Intel Motherboard
ASUS P5N-E SLI AND A GF7600 ..BOOTING PROBLEMS ..CORRUPTS
Hi, trying to boot from your old drives is the problem.
The Boot sequence for your new board are different from the ol one. Your sequence to get your system going is to load the mobo drivers first, then run your XP disk again and at the second prompt select REPAIR this will run the same as a normal install but should save your existing data and settings.
One problem you may have is activating XP as Microsoft do not approve of multi installs and the new board will show as a different computer.
Regards mistyman
Nov 29, 2007 | Intel Motherboard
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS ENGTX580/2DI/1536MD5 - Graphics adapter - GF GTX 580 - PCI Express 2 0 x16 - 1 5 GB GDDR5 - DVI PCI Express Video Card Logo
215 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
