Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
HOW TO SOVLVE PROBLEM COM SEVER TIME. ERROR 99
  • Canon Master
  • 3,530 Answers
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you
Posted on Jun 06, 2011
Error 99 come out
google make and model we can not assist without proper information
Apr 08, 2015 | Cameras
How to find outputs of a 4 variable input truth table
This link explains in detail how to sovlve your question.
http://www.wisc-online.com/objects/ViewObject.aspx?ID=DIG802
Oct 10, 2013 | 2001 Audi A4 - Sedan, chassis code B5 -...
Not used the camera for some time. When I try to take pictures I get the Error message Err 99. Shooting is not possible.Turn the power switch to <Off> and <On> again or re-install the...
hi the err 99 usually stands for shutter problem. however, there are several different causes. The first is defective shutter unit, second is defective power diaphragm unit in lens, and main PCB defective. You have to bring to your local repair shop. they would charge you around $65 to $235 depend on what it really cause problem. you can verify lens or body problem. try to operate without lens if still see err 99 when you push button. then it is body problem... Good luck with you...
Aug 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I can't print out doccument, the error shown "Unable to clean 46" Your prompt help would much appreciated. Niti
press "menu" "black start" and "up arrow 4 times".
that gets you into maint. mode to be able to reset purge counter.
next enter code "80" by pressing up/down arrows and pressing "ok".
press "black start" several times until you see "purge count".
now press "2783" and "ok" to reset purge count.
then press "black start" about three more times or until you see flushing count. again, press "2783" and "ok" to reset. now hit "stop/clear" a couple of times and press "99" to exit or use arrows to get to "99" . at this point, you may have to press "ok" to get out of maint. mode, but i think once you press 99 it backs out automatically. next time this comes up however, you will need to have your ink absorber box and flushing box replaced.
May 20, 2011 | Brother DCP-330C All-In-One InkJet Printer
I have cannon EOS 400D problem is error 99, some times after shooting
Welcome to Fixya
Have a good one!
Apr 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
99 error, CF memory card was removed to download pix. put CF card back in camera, but now get error message. removed battery and card several times, including replacing with another card. still get same...
Thank you for using Fixya!
Feb 13, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Several times I M TRAYING TO FAX PAPER ,LETTERS, DOCUMENTATION ....ETC...ETC....BUT ALWAYS I GET THIS RESULT ERROR 0404----ERROR 0407--ERROR 0400 ......
Well. I just got frustation the last 2 hrs trying to fax using my workforce310 through Ooma (nopay/basic) service. Finally, tried the unconventional way and got it to work several time without any errors. I did the opposite of the instruction (1) turn ECM to On and V.34 to On. (2) dial with *99- (you can get the dash by pressing redial/pause button) and then the 10 phone digits, including the 1.
The only message I got after is that my fax has been sent in black&white because the reciver fax is not color capable. Isuspect error 0404 is to indicate this problem. Hope its help.
Aug 19, 2010 | Epson WorkForce 600 All-In-One InkJet...
Error 99 message keeps popping up
Hi
I just read that the error 99 problem is a shutter failure and the shutter will have to be fixed. The cost is about $180.
see http://www.mcvr.com/canon_digital_rebel.htm?gclid=CJqG4cvc05oCFRMhnAodCHUA3Q#shutter
ERR99 (error 99) is an indication that there is a communication problem in the camera. It is most often an indication that the shutter needs to be replaced, but it can be the result of other problems. All digital cameras occasionally need to have the shutters replaced. In the days of film cameras, it was rare to wear out a shutter because the cost of film and developing limited the number of times the shutter was cycled. With all those ones and zeros being considered "free" in digital cameras, it is not uncommon to take several hundred or more photos in a day. Even with a live-expectancy of 50.000 to 100,000 cycles, the shutters in digital cameras do reach the end of their life and need to be replaced.
Shutter replacement (usually associated with error code "99"):
  • Replacing the shutter on the Digital Rebel series requires more disassembly than most other repairs.
  • The estimate for shutter replacement is $180 on all EOS Digital Rebel models (depending upon the overall condition of the camera).
  • ERR99 error codes are related to shutter or mirror operation and are usually associated with a defective shutter. Cameras that have had heavy use may have shutters that have reached life expectancy and need to be replaced.
May 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Brother printer dcp-330c error 46
press "menu" "black start" and "up arrow 4 times". that gets you into maint. mode to be able to reset purge counter. next enter code "80" by pressing up/down arrows and pressing "ok". press "black start" several times until you see "purge count". now press "2783" and "ok" to reset purge count. then press "black start" about three more times or until you see flushing count. again, press "2783" and "ok" to reset. now hit "stop/clear" a couple of times and press "99" to exit or use arrows to get to "99" . at this point, you may have to press "ok" to get out of maint. mode, but i think once you press 99 it backs out automatically. next time this comes up however, you will need to have your ink absorber box and flushing box replaced.
hth,
razors
Mar 30, 2009 | Brother DCP-330C All-In-One InkJet Printer
Error 99 Code on 5 month old Canon 40D
error 99 can be several things. Try the following. Check that the contacts on the lens housing are clean if not clean them with a swab of denatured alcohol available at walmart. also if there is extremely cold weather your shutter could be creating the error. Try using a blow dryer and on the warm setting warm up the camera with the lens off. Blow around the mirror area. I know it sounds silly but it has worked in the past. Good luck.
Feb 20, 2008 | Canon EOS 40D Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
