Question about Panasonic Televison & Video
The regulator IC always damage even if we are replace another regulator IC together with the resistor .47ohms..
  • Panasonic Master
  • 17,130 Answers
You need to check the drain into the circuit as the regulator fails ONLY when the current drain exceeds the limit and thereby damages the fusible0.47 resistor.
Either you can use a higher rating of the regulator or you need to check the drain current to see if any component is faulty.
Posted on Apr 06, 2011
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
In asus P5GL-MX mother board the power supply regulator ic 2 piece has been damaged (short) how would i know plz help me
Hi if the regulator ic has been damaged in your power supply even you replace that there are some electronic component where also damage because the ic will not damage where there is no over voltage flow on it. This means there are some resistor or a transistor is also shorted it advisable to replace a new one than to repair your power supply. Because even you repaired it the performance and the life span of your power supply is not stable. So it better to replace a new one.
Jul 14, 2011 | ASUS P5GL-MX Motherboard
The regulator IC is always damage and the resistor .47 ohms...
Hello
Check for any short circuit on the output stage of that regulator IC. you can detect it with the help of a multimeter, set to Ohms range, by mesuring its output to negative. OK.
Apr 06, 2011 | Televison & Video
Error Code 2-2. (Low Voltage Supply) What now?
That is a power supply issue and this requires a skilled person to do it.Trouble shooting in this kind of problem includes voltage measurement and resistance reading of the components/parts inside the high voltage section This is not a DIY problem but if you still want to do it yourself then I can give you some guide that you can try.
1.Check the power supply board,this board is where the power cord is connected.The common problem on this circuit are the filter capacitors .A leak and shorted capacitors always cause that kind of problem the worse is dead set.To visually identify a defective capacitor is their appearance they look to be bulging on top blown,theirs a liquid leak on the body.replace the defective capacitor if you found any.with the same rating and value..
2.Resistors -change value resistors and open resistance can cause the same problem this resistors usually near the regulator transistor.They appears as burned and overheated replace it with the same rating there is an available color code calculator of resistor in the internet click this link and key in the color of the resistor to get the value..
3. check the voltage regulator transistor if it is shorted .the first pin and second pin must not have a reverse reading..
4.Check also the two big IC marked with STK xxxx this IC are the convergence IC it controls the horizontal pin of picture..when this IC are defective this will shut down the power supply ..
The steps I mentioned must be done with a skilled personnel If you feel you can do it,well you can try or better yet bring it to the service center or call a service technician...click this link for service center
good luck hope this helps!
Feb 06, 2011 | Mitsubishi VS-60705 60" Rear Projection...
PT-53WX53G still shutting off-3 blinks
have you checked the 2.2 ohm 2watt resistors? If the led blinks three times the resistors will almost always have at least one that will be blown and need replacement.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Yamaha Portable piano - Loud 50Hz sound only on mains
MAKE IT THIS WAY FRIEND, IF YOUR POWER INPUT IS OK, AND THE OUTPUT IS FINE, THEN GO FORWARD FOR THE NEXT STEP, IF YOUR LA4558, (2CHANNEL AUDIO OUTPUT IC) IS HEATING UP, THEN JUST CHANGE THE IC, ALSO CHECK FOR CAPACITORS, ANY SIGNAL DIODES IF HAD DAMAGED, AND RESISTORS NEARBY...CHANGE THE AUDIO AMP
Oct 16, 2009 | Music
Triple vison/WHAT IS AN ic?
If your colors will not line up on the television screen using the convergence menu, the most likely cause is that the convergence IC’s in the set are damaged and need to be replaced.
IC’s are just many small circuits built into one package, many diodes, transistors, resistors, even regulators and power supply circuits, they can be various shapes and sizes.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are fastened to a large heat sink because they generate a good deal of heat. Finding these is not that hard, but there is supporting electronics that will also need to be replaced during the repair. There will be fusible resistors and feedback resistors that may have been damaged at the same time.
If you choose to repair the set yourself, be very careful of the high voltage that can be stored in the capacitors, and CRT’s. This voltage can be as high as 30,000 volts.
Unless you are very handy with a soldering iron and reading color codes on the resistors. I would recommend that you have a local television service center have a look at it and get an estimate for the repair.
I don’t use the cheapest parts when I repair this circuit, because I have seen the cheap IC’s damaged as soon as power is applied. I would also recommend that when the IC’s are replaced, whoever does it, that they use plenty of heat sink compound and remove the old compound first.
I guess you are wondering how much this repair would cost.
Not knowing the labor rate in your area and diagnostic fees, I can only give you a ball park figure. I have done this repair for between $375 and $450
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 29, 2009 | Samsung HCL4715W 47" Rear Projection...
Set dead
That code always be for audio amplifier IC damaged.Change it
Jul 09, 2008 | Panasonic Home Theater System System
Receiver fuse continuosly blows when replaced and powered up
Ir's not likely to be a resistor. Sounds like a shorted component in the power supply. A diode or bridge rectifier, or possibly a transistor or Regulator IC.
Hope that helps...
Geno
Apr 03, 2008 | NAD C720BEE Receiver
Televison & Video Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
