Question about Microwave Ovens
My stoves elite g500 will light occasionally on the ignition but will light ok with a match how do i fix it?
  • Microwave Ovens Master
  • 17,129 Answers
The spark is not good enough to ignite and so the coils must be checked. Clean the igntion points, check the switch and test if there is any clogging of food, dirt with moisture that is reducing the spark. Remove clean and reset this section.
Posted on Apr 06, 2011
How to turn the oven light off on my Kenmore Elite Electric stove model790.
You should have either a shorted out door switch or a shorted out light switch on the control panel.
Removing either one and unplugging it should show you which one is the problem.
God bless your efforts.
Nov 30, 2016 | Kenmore Microwave Ovens
Elec-ignighter on gas stove top not working
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Microwave Ovens
I got the automatic ignition on the stove top wet last night and it will not ignite the gas
I always wipe the area with a paper towel. The I turn on the gas and ignite it with a match or lighter. Let it run for a little while and it should dry out the ignition so that it will light automatically the next time, I hope this helps. You may have to do it two or three times to assure it's completely dry and capable of lighting.
If this helps, please come back to Fixya and rate my solution!
Jul 14, 2011 | GE Microwave Ovens
I have a jenn-air stove The igniter went out on all 4 eyes on the cook-top
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Dec 25, 2010 | Microwave Ovens
Top left burner (propane) does not seem to be receiving gas when trying to ignite it with electrical igniter (control knob). However the burner can be lit with a match when the control knob is turned past...
The igniter usually sparks for all burners on the stove at the same time. Usually a little water or gravy, or such has gotten on the little spike that stick up and throws the spark to the burner. If you will take a small brush, like a tooth brush and carefully clean around the little spike it normally starts sparking again. As it is right now, you should be able to see the spark on all the burners whenever you start any of the burners. Check to see on the one that is not lighting, I think you will find that it is not sparking at all right now.
Sep 21, 2010 | Microwave Ovens
My gas hotplates ignition switches are not working. How do I fix this.
heatman101
Sep 02, 2010 | Microwave Ovens
I have gas to all appliances in my home but range will not lite. Part time reidence so range has not been used recently. Is ther a reset system? Igniters are working OK.. Tom
all it needs is a spider to get into the pipe work and this will stop the gas mixing in the burner,, or a little corrosion on the jets will stop it too,
you may just have a lot of air in the gas pipe will the range light with a match? or do it just blow the match out? if so your just blowing air not a good gas mix?
Aug 05, 2010 | KitchenAid Microwave Ovens
My microwave lost all power.
The plug should be located in the small cabinet above the stove. Leave it unpluged at least for 10 minutes. Mine does it occasionally when it gets hot. I haven't had a problem since I turn the fan on when I run it.
Apr 04, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
127 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
