Question about Gigabyte GA-G41M-Combo Motherboard
Having installed this motherboard in the case and connected up I get a series of fast beeps a few seconds after power-up. I have immediately powered down. What is causing this problem? There is nothing in the manual about beep-codes.n@talktalk.net
  • 120 Answers
In your case, it is a memory problem. It's either one of your RAM has problem if you have 2 slot RAM. Please ensure that you have the right RAM for your board. You can also clean the contacts of your RAM by using eraser.
Below are the most common beep code that being adopted to most BIOS for reporting.
  • short beep - Normal POST(system is OK)
  • Steady short beeps - power supply problem
  • long continuous beep - memory failure
  • Steady long beeps - power supply problem
  • 1 long, 2 short beeps - video card problem
Posted on Apr 06, 2011
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
Will not power on.
check the power supply
and the power button
May 12, 2011 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
When i plugged power cable to my pc cpu fan start without press power button
It should start for a few seconds, the fans should spin and then stop. You should be able to power it up as per normal. If that is no the case then you are having hardware issues which could be the Power supply
Apr 03, 2011 | Intel 845GE Motherboard
Get a series of error sound and 2 beep sound at the end when turn on my hp pentium4 and the system refuse to come up. pls, what could be the problem. thankx
Anything MORE than ONE beep indicates that the motherboard has detected a problem:
* bad RAM
* RAM not correctly "seated" in its socket
* one of the fans powered by the motherboard (CPU, case) is not spinning, or is not spinning fast-enough
* bad video-card
EXACTLY what sequence of "sounds/beeps" you do hear?
Jul 30, 2010 | EliteGroup ECS 661FX-M Main Board Socket...
P4vm800 not working how to solve this probelom
Good day sir, hi, lets make sure first that your motherboard is good, so we need to test it, just prepare the folowing items.
  1. A good working power supply, to test: place a jumper wire across the green wire and any black(or sometimes the red with work) wire on the 20/24 pin power connector. Plug it and see if the exhaust fan run.
  2. A good set of Ram, just make sure its good. if not or in doubt buy new one (only one module) if you want. (you can keep the doubtful ones and test it later)
  3. A keyboard.
  4. If your motherboard has no VGA onboard, A good VGA card.
  5. A thumb speaker, or you can use your PC case speaker.
Okay lets assemble, on a table:
  1. Place your motherboard, (make sure no metals underneath) connect the Power Supply 20(or 24) pin to your motherboard and the 4 pin 12v connector. (if your motherboard has one).
  2. Connect the pc thumb speaker or your case speaker.
  3. connect the keyboard.
  4. connect the RAM, make sure it clicks as you install it.
  5. Optional VGA card. Onboard vga will do. Connect a monitor. plug in the monitor.
Okay, plug in your power supply, (exhaust fan is off at the moment) locate the power button pins, short them with a screwdriver. (fan is now on)
Now check your Keyboard. you will see two sets of lights, first set is Num Lock + Scroll Lock + Caps Lock, then a few seconds the second set: Num Lock only. at this point your motherboard is good.
Also check out the PC speaker beeps.
  • 1 beep mean good.
  • 1 long and 3 short beeps VGA is bad. (it may help if the VGA is snug and fit on the slot). If on board VGA, use a new AGP/PCIe card.
  • Continous long beeps. cannot detect memory
  • Continous short beeps, motherboard. (or memory sometimes).
  • No beep, fan is on.at this point do everything again. (do it several times until the board responds)
Hope this helps you. feel free to ask again.
Oct 14, 2009 | Asrock P4VM800 Motherboard
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
POST-Beep-Code List availible for Phoenix-BIOS? ECS 755-A2
The problem is with your RAM. Try installing the RAM in another slot. Install your AGP card slowly. I can assure about your motherboard yet you have no problem without assembling. Keep informing.
Feb 22, 2009 | EliteGroup SiS755 (755-A2 V1.0)...
Constant beeping every 2 seconds
a constant beep indicates either a power supply, motherboard or keyboard problem.
If you know what you are doing then open up the case (turning off the power first of course and earth yourself by touching the case before anything inside it) and make sure all the connecters are seated properly and try a different keyboard if you have one.
Oct 26, 2008 | Gigabyte GA-K8VT800 Motherboard
Won't power up
It has to do with the KT-600 series "anti burn regulator" and how it has a hard time with the XP2600 thru 3200 CPU's because they get so hot so fast... Try pressing the power on button again immediately after the long beep ends. Your computer should boot right up. Or, you can disable the ABR by removing the jumper from the pins on the motherboard. I haven't tried this because I like knowing the ABR works so good. It only takes a second or two to fry a CPU.
Feb 19, 2008 | Soyo KT600 Dragon Plus Motherboard
Gigabyte GA-G41M-Combo Motherboard Logo
490 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
