Question about Brother MFC 210C All-In-One InkJet Printer
Where to plug the usb cable into the printer?
Cannot find the USB cable plug in on the printer
  • 446 Answers
you wont miss this, pls try again see image
Posted on Aug 06, 2008
LIFT THE COVER THE PLUG IS UNDER IT
Posted on Aug 12, 2008
Where do i inset the cable from pc
That depends on the make and model of the printer, every printer is different. However, generally speaking if it's a USB printer (as almost every modern home printer is these days) The USB port is normally found at the back of the printer.
However, the usb cable from pc to printer isn't the same at both ends (as you might expect). It's a USB (A) that plugs into the computer and a USB(B) cable that goes into the printer: netean.jpg
Look on Google images for USB B for more examples. In the above image (courtesy of Lindy.co.uk) the plug on the right goes into the printer.
Feb 28, 2011 | Office Equipment & Supplies
How to conect the printer to the computer?
you will need an USB printer cable.
they don't always come with the printer. :(
Oct 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
CDP78 USB Device Not Recognized
HOW did you re-install everything ?
Make sure you UNPLUG the usb cable first, then UNINSTALL the drivers and all software - reboot your computer - make sure at all times your usb cable is unplugged from the device - once cleaned and unisntalled - re-install drivers and software - BUT still, do not plug the cable - ONCE and only once the drivers are installed, then plug the USB cable, inspect the USB cable to make sure it's secured. Have you tried unplugging your printer for a few minutes and plugging it in again ?
IN windows device manager do you see the device listing with a yellow exclamation mark ?
If all else fails you may have a faulty circuit board on the printer.
Sep 26, 2009 | Vinpower Digital U-Print CDP78 Printer
Dont know if I have the right cords specifically what is the connection process.
If you go to the Canon support site here you can downlod easy setup instructions. This page has some other manuals and user guides that may also be of use.
Here are the basic usb cable instructions:
Connect the USB Cable Correctly (i70 / i80 / iP90) Instructions to connect the USB Cable Correctly to the printer (i70 / i80 / iP90). Before connecting the cable
After confirming the printer and computer are turned off, connect them using the USB cable (sold separately).
Note: Below is an example of what a standard 'A to B' USB Cable looks like.
How to connect the USB cable
  • Plug the flat connector of the cable into the USB port of the computer.
    Note: If there are two or more USB ports in the computer, any available port may be used.
  • Plug the squarish connector of the cable into the USB cable receptacle of the printer.
<1> Computer's USB Port
<2> Printer's USB Cable Receptacle
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 20, 2009 | Canon PIXMA iP90 InkJet Printer
Where do you plug the usb into the printer?
I THINK YOUR USB CABLE PLUGS INTO THE BACK OF THE PRINTER NEAR THE bottom.some printers do not come with a usb cable.so you may be unaware that usb cables have large and small ends.you should be able to recognize socket on printer if not you may have the wrong cable.RICHARDM69
Dec 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP F2200 all in one/ usb
As you are receiving the USB device not recognized whenever you plug in the USB cable, the problem could be either due to the corrupted USB drivers on your computer or the USB cable needs to be replaced. Try updating your USB drivers and/or replace the USB cable. I am sure that the issue will be resolved.
Nov 23, 2008 | HP DeskJet F380 All-In-One Printer
Inability to install hp psc 1310 series printer
uninstall the previous installation, restart your pc remove the usb printer cable, reinstall the printer driver donot plug the usb cable until the installation program tells you, then plug the usb cable, if it is detected its ok if not replace the printer cable with usb2.0 maybe the usb cable is defective.
Aug 06, 2008 | HP Computers & Internet
Bluetooth
My MP500 has a normal flat USB plug in.  Turn off your printer and just try plugging in a normal USB cable into that slot...You can use the printer cable if you want. Haven't rec'd the BU20 yet, but don't think it will be a problem.
Oct 05, 2007 | Canon BU-20 (13803055436) Print Server
Inkjep printer
Unplug the printer. After uninstalling the software make sure you delete the printer from Printers and Faxes! Try plugging it up again(don't install back the software just as yet), the New device found pop up should come up! if it doesn't then it could be the USB cable / the USB ports on the PC or the USB interface on the card! If it does , put the cd in the drive and select Install Drivers automatically(if its pops up) Also, Try using different USB ports if the new device pop up doesn't pop up! Test the USB ports by using a regular USB device in the same port you are plugging the printer into! A bad USB cable could be the issue but it can also be something else! You'll need to verify that its the cable, what you can do is try it with a cable that you know is fully functional! If you still don't get a response from the printer and everything else works(i.e. usb cable, usb ports) then it could be the USB interface on the printer! and you'll need to take it to a tech! Hope this helps!! regards, babb
May 04, 2007 | Epson Stylus Photo 1280 InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
106 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
