Question about HP Computers & Internet
I jusst baught a new laptop.When I hit the button to make ilt louder or lower (volume touch buttons) the volume sign apears on the screan and gets stuck
  • Burchiu_radu Aug 07, 2008
    Yeah,I tryed that but no luck :(.It works directly from the mixer but the quick buttons or the remote work only from time to time
    Champion:
  • 221 Answers
Try incresing the volume manually in windows. otherwise reinstall drivers for your keyboard
Posted on Aug 06, 2008
The volume on my plasma tv goes up to 100 and when i lower the volume it will take a second volume for the volume to go up to 100 how can i fix my tv to lower the
The tact switch is most likely defective which is keeping the volume up engaged. Replace the tact switch should fix the issue. If not the button assembly pcb will need replacement. You can get replacement boards from www.tvcircuitboards.com
Dec 10, 2012 | LG 60PC1D 60 in. Plasma Television
HI I am just new on laptop and.....
You can either right click on the bottom taskbar and click on properties
and add the volume to the taskbar, or you can go to start, control panel,
sound, and turn up the volume.
It depends on what you are using to send email, outlook express
or a email like yahoo,hotmail. live google, if you use one of these
you do it with these site.
The touch pad has two buttons, it can do everything a mouse does.
The touch pad just moves the mouse, the left and right button is the same as mouse buttons.
Feb 08, 2010 | Acer NSK8458AN Keyboard
When you push a button on the remote, it either does nothing, or the channels start flipping all the way through from 2 to 120 and then start over. It is the same with the volume, if you hit it, it just...
If it doesnt happen when you change the channel or volume on the tv itself then i would recomend getting a new remote. You could probably get one on ebay. Most manufacture remotes will work on all of their tvs.
Nov 18, 2009 | Polaroid Televison & Video
Ring
On most Uniden phones, just press the Volume up key to turn the ringer back on or turn the volume up, the more times you press the button the louder it will get. Conversely, pressing the down volume button will lower the ringer volume, and on some models eventually turn it off.
Mar 25, 2009 | Uniden Cordless Phone
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Hard reset for a HTC Touch Diamond
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
Volume
hi pkeyes40, my phone is a differenet model number, but on my phone you raise the volume by hitting the hands free button, then press the delete button several times to adjust the volume ( 1-4), then press the hands free button to confirm. then hit delete to exit. hope it works the same for your phone. good luck. and if you would like me email you with the manual i have for my phone, an innovage lcd phone/caller id 1507102, it might give you some pointers. my email address is all8upinwv@yahoo.com
email me and i reply with the manual. hope i helped ya out. good luck.
tammy
Mar 27, 2008 | Innovage Touch-panel Phone 1502084
Turn volume up on ipod nano 3g
click on the middle button and then u shows you the volume and then u click the right button to make it louder and left button lower!!!!!!!
Jan 23, 2008 | Audio Players & Recorders
How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
Jan 02, 2008 | GE Cordless Phone 900 MHz
Volume
Hit hands free button then the vol. button the once agian to change it from high to low.
Jun 13, 2007 | Innovage LCD Touch Panel Phone
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
