Question about Sport & Outdoor - Others
Repco 302 treadmill showing CU-0 and won't start
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Error 1 comes up after
I am sorry to hear regarding the trouble.
This is a common problem and we came across this E1 error on most occasions in our shop.You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 07, 2011
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
Need manual for RE1000 treadmill
please download from the website www.manualslib.com
God bless you
Dec 15, 2012 | Exercise & Fitness
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
Repco fitness Treadmill error E7
This happened to mine, e7 is an error in the incline, meaning that the incline is too high or too low in the accepted range for the starting position of the treadmill. When the treadmill starts it looks to see if the incline screw shaft of the incline motor is in the correct position. If it isn't it gives the error message and shuts down. This happened to us after we had moved and the treadmill was bumped around a bit, this caused the incline worm shaft to move out of position, and that is why we got the error message.
To fix the problem I just took the cover off the motor area of the treadmill (WITH THE POWER OFF AND CORD DISCONNECTED) and located the incline motor, it has a threaded rod and a big nut coming along side the motor itself. It is the smaller motor. On the end of the threaded shaft is a plus sign cut into the shaft, so that you can insert a philips head screw driver into it and rotate the shaft. The shaft will rotate easily in one direction. Insert the screw driver into the end of the shaft and rotate the shaft so it goes as far into the big nut holding it as you can, don't twist it tightly, just make sure that the shaft has gone all the way in without binding, it still needs to rotate freely in and out. Put the cover back on and then switch it on. The treadmill should now start right up.
Mar 26, 2011 | Exercise & Fitness
The incline of my treadmill started going up on it's own
Hello there:
it is looking like the touch pad is failing, you may want to get it serviced by a certified technician. best regards mike
Aug 08, 2009 | HEALTHRIDER S600 Treadmill Motor Control...
Repco Sports Treadmill
Repco RP300TM wont start E1 error message
Jul 15, 2009 | Exercise & Fitness
Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
Jun 05, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
