Question about LG Washing Machines
Have a lg FRONTLOADER WASHING MACHINE AND NEED TO CLEAN THE DRUM AND PIPES AS MY WASHING HAS A TERRIBLE SMELL?
    Brigadier General:
  • 6,277 Answers
Check the filter first and here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 06, 2011
Low water level
Clean the intake filter and drain pipes
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
How to Clean the Inside of Washing Machine
Sep 10, 2016 | Washing Machines
Tip
How to Stop Mold or A Stagnant Smell from Washing Machine.
If your washing machine is producing a stagnant smell which is tainting your clothes then this Tip is for you!
Secret ingredient: Ordinary Baking Soda.
First check to make sure that the machine is draining properly and ensure that the pump filter is clear of any debris. Check that the drainage pipes at the back of the machine are not kinked or obstructed in any way.
If the machine is a frontloader a common place for mold to build up is the rubber seal gasket around the door such as this one. Immediately you can see the nooks and crannies where mold can build up.
Mold is one of the most common causes of a stagnant odour.
Clean this out as well as you can with ordinary kitchen cleaner (avoid using bleach) then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Baking soda has a cleaning and neutralising effect and will help remove any build up of mold or gunge within the machine. You may need to run two of these washes before you see a solid result.
Thereafter I recommend you run a monthly 'maintenance wash' with the baking soda to prevent the problem arising again.
It is highly recommended that the door of the machine is always left partially open between washes as this encourages ventilation and discourages any more mold from forming inside the machine.
If you found this Tip helpful please take the time to register your vote using the buttons below.
Many thanks for using FixYa.
on Dec 19, 2009 | Washing Machines
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
I have a Westpoint Frontloader washing machine. Everything goes well untill it starts spinning. Then is starts shaking and there's a lot of noice. We did make sure that it is level. What else
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | LG Washing Machines
Terrible smell coming from our washing machine
remove bottom cover at back of machine, loosen large jubilee clip on hose between drum and pump. pull hose down and off, take out strainer basket and pull top off, clean top, ball and basket by running under tap. clean out hose with an old rag. reassemble strainer and put back into hose, in the correct position. fix hose back on to drum and tighten clip. run machine on a hot wash and all should be fine.
Nov 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Dirty smelly front loading washing machine
you need to find and clean the water return filter
Oct 11, 2009 | Washing Machines
Lg washing machine drum light stays on and wont let me turn the
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
May 15, 2009 | LG Washing Machines
Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Terrible mildew type smell
Water forms in the Bellows it is a rubber boot between the door the drum.. clean this out real well ..To prevent this in the future leave the door cracked open when you are done using the machine to allow it to dry out.
Aug 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG washing machine smelly drum
try the hotest wash not on a quick wash and put a hand full of soda crystas in the drum. you can buy these at most supermarkets.
Feb 15, 2008 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
