Question about HP PSC 1610 All-in-One Printer, Scanner, Copier
Printer error when i turn my printer on the screen indicates, "error:0x07d54dd6:2005:lib_barracu
  • 3 more comments
  • jvera Aug 12, 2008
    Same error message. different printer, Officejet 7210 All-in-one printer
    I had to remove the cartridges and re-insert them in order to getting to work again, sometimes I had to do it several times before it works.
  • gheeks007 Aug 25, 2008
    when turned on it reads Error:0X07d57dd
    2005:lib_barracu
  • SweetGA8800 Sep 02, 2008
    Same problem. I tried reinserting the cartridges, downloading drivers, nothing works.
  • Anonymous Feb 19, 2009
    Yes I have same problem, I sometimes manage to get it working again but I'm never quite sure how.
  • Anonymous Mar 15, 2009
    Same problem. No idea how to fix.
Just had this problem myself on my HP PSC 1610 All in one. After some fiddling, I found out that the power connector in the back was not fully inserted and must have slid out a little over time and with movement. After pushing it the whole way in, it started up fine and didn't give the error.
To make sure that was in fact the problem, I pulled the connector out slightly and started it up to find it gave me the error again. Then pushed it in the whole way, and it started up fine with no error.
Hopefully this works for others as well.
Posted on Nov 17, 2009
Well-me big dummy. I had another HP printer, and then got that same error message when I tried to install the 1610. I assumed all HP power cords are the same. They aren't. I put the correct one on and she be goin'.
Me big dummy
Treeman
Posted on Jan 02, 2010
Remove and reinsert the cartridges and turn on/off the printer, i did this once and it worked fine again.
Posted on May 08, 2009
  • Ascensor May 08, 2009
    Remove the cartridges, turn on the printer, turn it off again, re-insert the cartridges and power on, ta daa - should work!
3 Suggested Answers
  • 274 Answers
SOURCE: Error: 0x07a74dd61959:lib-barracu
I'd try un-installing printer, turn computer off (hard boot), and then re-installing. S\Could be a corrupted file but not sure.
Posted on Jul 15, 2007
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Posted on Nov 07, 2007
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
My samsung ml-1610 series printer's software is installed but the printer is not installed
my oj 7310 all in one is give me error mesege 0xc0620004 411:lib-micci2.c
Nov 03, 2009 | Samsung ML 1610 Laser Printer
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
I keep getting error 1-2070
Resolution
Check to see if the required files are present:
  • Go to C:\WINDOWS\system32\kodak. Check for 2 folders "kds_aio5000(for AiO 5000 series printers) and kds_aioesp(for ESP series)
  • Depending on printer model, open kds_aio5000 or kds_aioesp.
    • For kds_espaio it should only have the lib folder. It doesn't have the ekaiowia.dll
  • Inside the lib folder it should have cct.ekpgct, hippo.dll. Both for kds_aio5000 and kds_aioesp.
  • If hippo.dll is missing then try the following:
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Apr 12, 2009 | Kodak ESP 5 Printer
Error message
Resetting the EEPROM
1. Press and release the On button to turn the printer off.
2. Press and hold down the Stop, B&W, and the Color buttons.
3. Then press and hold the On button until the LCD screen flashes three times
4. Release all the buttons. The screen displays Init. EEPROM
5. Press and release the Color button again.
6. Press and release the On button to turn the printer off.
7. Press and release the On to turn the printer on.
Nov 26, 2008 | Epson Stylus RX500 All-In-One InkJet...
BIJ 2800 unable to print as error "-00D4-c3f9 LIB MICCI.DL212" error appears
HP All-in-One Products - Performing a Partial Reset of the All-in-One Introduction There are times when a partial reset may be required to restore the all-in-one to proper operation. A partial reset does the following:
  • Reset the user settings to the factory defaults.
  • Reset the language and country/region settings on some models.
Performing a partial reset Follow the steps below to perform a partial reset of the all-in-one:
  1. Unplug the power cord from the all-in-one.
  2. In the table below, locate the button combination for your model.
      NOTE: If your all-in-one model is not listed in the table, your model does not have a partial reset option.
  3. Press and hold the button combination for your all-in-one.
  4. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
Product family/model
Button press
HP PSC 2500 series
Press and hold # and 3 while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+ ) instead of # .
Apr 21, 2008 | HP PSC 2355 All-In-One InkJet Printer
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Jul 26, 2007 | Sony (LIB81A3BB) AIT-3 Tape Drive
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
2,336 people viewed this question
Ben Johnson
