Question about Dishwashers
Hi, the "start" and "end"(or
  • 5 more comments
  • Gerd Heil Apr 07, 2011
    Sorry, it is a Miele SCU 648. I think a solution would be the same for any dishwasher in the 600 series?
    I got a suspicion that the haeting device does not work
  • Gerd Heil Apr 08, 2011
    it will run a whole program including the drying fan turning at the end. When it is finished, "start" and "end" are flashing.
    it seems that ther is no heating of the water during the program
  • Gerd Heil Apr 11, 2011
    Hi, sorry, I submitted the answer once but it seems i t did not upload...
    The model should actually be danish... ;-)
    1. It wil run a full cycle including the dryer fan (thurbothermic) running in the end.
    2. It seems that the water is not hot during the cycle.
    thanks
    Gerd
    1. it will wash a full cycle including the dryer fan running at the end.
    2. It does not heat the water during the cycle.
    best whishes
    Gerd
    It seems i have made a real mess of my replies. Hopefully you got them?
    President:
  • 1,140 Answers
Hello Gerd,
Sorry for the delay in replying to you, but there has been a technical fault and we have not been able to answer your question.
It's impossible to diagnose the fault without knowing the brand and model number of the washer. Please reply to me with these details by clicking on "Add a Comment" below your question.
Thanks,
BElectric
Posted on Apr 06, 2011
  • DILLIGAF
    DILLIGAF Apr 07, 2011
    Hello Gerd,
    Thanks for the information. Sorry for the delay, but this is a German model, so I had to find information for the equivalent UK version. This may be a control module fault, but please could you assist my by answering the following questions:
    1. Will the dishwasher run a wash cycle?
    2. Is the water hot inside the dishwasher during the cycle?
    Thanks,
    BElectric
Error e51
All four LED's flashing together indicate an error that cannot be cleared by an end user. Normally a service call will be required.
I would recommend getting in touch with Brother or a printer technician.
Mar 26, 2013 | Brother HL 5250DN Laser Printer
RHEEM RTGL 74 XP FLASHING 80 AND CL
I know this is late, but I just went through this problem right now, or rather just a few minutes ago, after finishing the installation.
What worked was holding the up and down arrows together, this is usually what resets other electronics. Well, it worked. It caused the unit to reset and everything started working properly.
Again, while I know this is a late answer for you, I hope it helps others that were looking for a solution and could not find one, like myself tonight.
Sep 14, 2012 | Rheem Tankless Hot Water Heater...
I have a Miele SCU 648. The "start" and "end"(or
It is possible that a low water pressure can increase the time for the program and so this can lead to the program contrroller hanging up to show the flashing.
So remove the inlet and the water line to the inlet, check the filter and the inlet valve. If the pressure seems good , check the flow when the program starts.
Also counter check on the water level sensor, the drain pump/valve. finally check the winding on the heater using a multimeter, check the power to the heater during the program.
May 03, 2011 | Miele Dishwashers
My 2009 Hyundai Accent feels like transmission slipping while driving. If I pull over and restart it usually goes away. Sometime check engine light goes on. I bought it used in September 2010 and took it...
You should go to an actual Hyundai dealer . My angine lights started flashing one time with similar symptoms as what you described and they easily fixed it.
Apr 13, 2011 | 2009 Hyundai Accent
3 lights are flashing at end of dishwashing cycle cycle
I shut off the dishwasher, held a few of the buttons together at the same time, let it sit for 5 minutes, then restarted it and it worked!
Mar 21, 2009 | Miele Dishwashers
Our ls12 ev03 dishwasher won't turn on, every time it is switched on it says'I'm still drying' with it's flashing light evn when it has not been programmed to do anything
It could be that it was opened before it had finished its last cycle. When you switch it on again, it wants to finish. You could either leave it on until the drying light goes off, or force it to finish the cycle. I'm not familiar with that model, but on mine I have a Stop option on the dial. On the machine I had before, I had to press two buttons together to force the end of cycle. Worth a try. Good luck.
Jan 06, 2009 | Dishwashers
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
