2 hotpoint aquarius wml 540 drum paddles have come apart from the drum. Is there a way to refit or do they need replacing
5 Suggested Answers
  • 155 Answers
SOURCE: Drum Paddle broken Hotpoint Aquarius
The paddles in the drum are there to agitate the clothes being washed. Without them, it is possible that the drum would just spin while the clothes sat still at the bottom.
For optimum performance, it is best to have all the paddles present, but if one is broken/missing then it shouldn't have too much effect.
Hope this helps,
Matt
Posted on Mar 08, 2008
apart4u
  • 213 Answers
SOURCE: How do I replace Drum paddle on Hotpoint WF860 washing machine
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Posted on May 06, 2010
barkencoa
  • 3463 Answers
SOURCE: where can i find the
Try looking on the inside of the door as you open it
Posted on Nov 21, 2010
beltronic205
  • 1467 Answers
SOURCE: I have no power to
Chance is its the two pole off/on switch or door interlock , check switch first.....
Posted on Mar 03, 2011
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
I would like a washing machine manual
go to the makers internet site, type in for manuals your machine
Jul 27, 2014 | Hotpoint Washing Machines
Hotpoint Aquarius WM62 bearing noise how to change it
Hello,remove all the surround screws from around the door glass then gently lever the 2 halves apart,remove the old hinge,and re mount the new one along with the plastic bearings refit the screws,refit the door to the front cabinet.
Thanks
May 23, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius is not spinning or draining..f-05 is flashing on and off...
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean filter inide hose.
Refit and test.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Loose Paddle in the Drum
not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
Feb 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washihg paddle won't stay in
There is more than one version of drum paddles, assuming you have got the right one, then locate the paddle in the slots in the drum, and push firmly into place, you should feel it click in to place, to check, pull the paddle lightly back towards you, it should remain fixed in place.
Also make sure you have got it the right way round.
Please rate my solutrion.
Thankyou.
Jan 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drum makes grinding noise when turning
Hi.
spin the drum by hand, if it feels rough or is noisy, then you probably have drum bearing failure.
Another possibility is one or more of the drum paddles may have come adrift..
These can be replaced.
Nov 24, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
281 people viewed this question
Top Washing Machines Experts
