Copying and printing are unavailable. - Office Equipment & Supplies
"Set unavailable" error received when I tried to Set Copy on Norstar M7310 phone
Are you sure you have the correct extension number for the destination? I may be more than "not progammed correctly" - perhaps it isn't the ext# you think it is. Try Feature*0 then all the keys, especially the line keys, which should give you the extension number.
Apr 21, 2015 | NorStar M7310 Corded Phone
I am trying to print something and the printer is showing unavailable for the thins it does ie copy, scan etc
hi there even if its an all in one had to have different drivers for the print see that its installed get model no and that and download the from the epson wesite
Oct 30, 2014 | Epson Office Equipment & Supplies
Light copies
If parts are unavailable because you have an old machine, the practical answer may be to replace the whole machine.
Sep 15, 2014 | Office Equipment & Supplies
Internal power supply failure copying and printing
Here are the part numbers 105E 11660
Power Unit 110V
105E 11670
Power Unit 220V
Google a business called The Parts Drop, They should have that part.
Nov 26, 2010 | Xerox WorkCentre M118 Black and White...
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
Lost book. have 18lb. turkey. how much water to put in bottom of oven and how long to cook it.
Hello Rands!
Here's the manual for your use and reference on your Rival 18 quart roaster oven.
http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
According to the instructions, you should add about 5 - 6 quarts of water in the lower compartment.
Please download and print a copy of the manual for your use and future reference. I have made a file folder on my computer labeled "Home Appliances and Equipment" into which I save electronic copies of all my owner's manuals and guides, just in case they become unavailable from the internet in the future. That way, I'll always have a file from which I can review and print out a copy, if needed.
Enjoy your Thanksgiving and save me a drumstick! Hope you find this Very Helpful and best regards!
Nov 25, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Message tells me that my "printer is unavailable" when I try to print a pdf file
You can remove PDF password and restrictions with just 3 simple steps: Launch - Import - Decrypt, and support drag-and-drop operation
Nov 22, 2009 | Canon MX700 Office All-In-One InkJet...
Rpc server is unavailable
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Jan 29, 2009 | Brother MultiFunction Center MFC-440CN...
Printer staus unavailable at this time
A couple things I would check that can cause this, all related to PC to Printer communication.
  1. Cable problem: Printing locally with a non-bidirectional printer cable from LPT1.
  2. Configuration Issue: Printing via IP and having designated in the device setup more trays then actually exist. For example, checking that you have a feeder when you have only the default tray.
  3. Resource Conflict: Printing via IP when another device is using the same IP.
  4. User Error: Having multiple copies of the same printer. i.e. 8500DN, and 8500DN(1) setting one up but having the other set as default.
Jul 24, 2008 | Xerox Phaser 8500/DN Printer
59 people viewed this question
k24674
