Question about Bosch Exxcel WFO 2264 Front Load Washer
Bosch Exxcel 1100 WFO2265GB/01 is missing the rinse part of the programme and seems to continue on WASH with 1min left, ad infinitum or until I switch it off and put onto the rinse programme. I thought I might be overloading it but seems to do same with very little load. any suggestions gratefully received. Thank you!
    Brigadier General:
  • 6,277 Answers
It could be that the washing cycle water is not draining away either because there is a blockage in the filter or the drain motor is malfuctioning.
Here are my (complete) guidance notes for checking both the drain motor filter and the drain motor ;-0)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 06, 2011
On auto programme for the BOSCH SGS43A18GB/27, it will not rinse.
see this possible caues:
Water-heating cycle
the heating element will be faulty, see the video, the water must be preheated
Timer:
test for wiring broken, loose, or burn, or timer defective
God bless you
Jun 18, 2012 | Dishwashers
Bosch exxcel multi programme ....programme gets to 1 min and then stays there. on the quick cycle on the auto cycle it gets to 60 min then returnsto 140min on the timer... thankyou
this is caused by incorrect water levels the appliance takes in too little water at final rinse and generates erro code 1 this is what you are getting it isnt 1 minute to go it will need the dishwasher equivalent of colonic irrigation several tubes will be full of fatty deposits,using the quick wash a lot will make this happen more often you will need an engineer to sort but shouldnt need any parts.
Aug 06, 2009 | Bosch Dishwashers
Bosch exxcel programme runs until 1 min left and won't finish
This is a fault code which indicates it has not heated through the programme
Dec 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
We have a Bosch Exxcel Washer Dryer and it seems that at the end of any programme, the washer does not drain and spin (but does drain and spin in independent programmes) - it just continues at 0.01 mins...
would try cleaning your pump and sump as when its draining without the force of the spin the pump is idle but with the force when you put on other programs ie the spin this will push the water through the pump hope this helps
Jun 22, 2008 | Washing Machines
Dishwasher pumps water in and out, but does not wash
Try tilting the machine back 45 degrees for one minute 7 then try one of the programmes. Serousely outr Bosch diswasher was firstly not draining water then not taking in water & another forum suggested this odd manouvre & all is fine now
Nov 06, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Exxcel WFO 2264 Front Load Washer Logo
118 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
