Hello, my problem lies with the Tripod NBWAE LA-5831P (Toshiba L455D) motherboard. I need to reset the power to CMOS, so I can reset the BIOS back to default. Problem is, I can't find any battery, or jumpers to set. I also have been unable to find any sort of manual for the motherboard with schematics. Doh! Any help would be greatly appreciated. Thank you for your time.
sandrew
  • 2961 Answers
SOURCE: T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need http://www.intel.com/design/motherbd/sr/sr_con.htm#IC
Posted on May 06, 2007
migregorio
  • 42 Answers
SOURCE: Advent 7110 bios password hell
ftp://ftp.sabioproducts.com/pub/Notebook/EF6C/EF6C_Service_Manual
I believe this is the manual associated with this Advent laptop. Select "disassembly instructions". Item is a viewable PDF document.
Posted on Apr 13, 2008
kornho
  • 781 Answers
SOURCE: Need to reset phoenix bios
have yout tried this application..
http://www.cgsecurity.org/wiki/CmosPwd
I've heard before about the toshiba paralell loopback (it's also mentioned on the website above) as a way to unlock your bios you may want to try that aswell.
post back if it worked.. would be good to know if it did.
I remember also reading about the possibility of flashing your bios (you're going to need a floppy drive unit) to at least unlock your hard drive and get your data out, you may still not be able to hack into the bios again.
Posted on Oct 01, 2008
ginko
  • 19396 Answers
SOURCE: jumper settings
There is no jumper settings, it is just a small bridge aside the bios Chip. you bridge the two pins and power to reset cmos.
A much easier way is removing the Cmos coin shaped battery from motherboar for few seconds, and put it back, this will reset Cmos the same .
Posted on Oct 10, 2008
drlalitv
  • 488 Answers
SOURCE: removed my CMOS battery, but the BIOS settings won't disable
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and
3. Your reset is now complete
There might also be an option within the BIOS to "Load Defaults" if that is all you are looking to do
please see this http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/
hope it helps!
Posted on Nov 04, 2008
Toshiba Satellite L455d-S5976 Bios password locked then shuts down?
If your trying to get into BIOS to change settings and you forgot password you have to reset CMOS whitch set system back to default. This physically done inside computer using the jumper pins on south bridge of motherbaord.. Its a little differant on some systems so you will have to somehow refer to service portion of cumputer management inmanual or find access to MFG website for info how to reset CMOS on your system. However there is software you can obtain that you put on a USB and reboot system and tells you the passwords to the computer, but you must be cautious when useing this software exspecially when there is two operating systems installed so proceed with caution if you go this route. Good Luck !
Apr 15, 2014 | Toshiba Satellite L455D-S5976 Notebook
Where is my cmos?
The CMOS = BIOS is a IC chip on the motherboard.
Apr 15, 2012 | Toshiba Satellite L455D-S5976 Notebook
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
Hello, can help me, my laptop ACER EXTENZA 4630 SERIES, why i can open the password bios when i re install the laptop..? thanks
Yes by default the bios is unprotected/no password. All you have to do if you want to setup bios password just go to bios then create supervisor password then it will have password everytime you need to access the bios. For info. bios password is not related to re-installation / installing your OS.
Mar 12, 2011 | Computers & Internet
How to disconect hard drive on l655n forgot bios password
You do not need to disconnect your HDD. There are different ways to reset the BIOS password. To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
With the Toshiba laptop last resort would be opening it up as the battery is most likely soldered to the motherboard.
Feb 15, 2011 | Toshiba Satellite L455D-S5976 Notebook
I NEED REMOVE BIOS PASSWORD TOSHIBA SATELLITE X205 S9349 PLEASE HELP ME
You will need to reset your Bios.
The only way i know t do this on your model is to remove the backup battery usually under the keyboard or in another compartment. You will also have to remove the primary battery and power cable.
Thanks
Dustin
Jan 17, 2011 | Toshiba Satellite X205-S9349 Notebook
Forgot my cmos password need to reset it in my toshiba p505d s8935 laptop
It is difficult to reset the BIOS password.Only the reason it is the back door password and locate behind the BIOS chip .
I am giving a link you can try from here there is 50 % chance to reset the password.
Fallow the bellow link.
http://jevarax.wordpress.com/2008/08/08/how-to-clear-your-toshiba-bios-password/
Regard's
Shibuds
Jan 05, 2011 | Toshiba Satellite P505D-S8935 Notebook
Toshiba Satalite A215 Laptop Bios Password
remove battery.....wait for 3 minutes....put it back and turn on...the bios wii get reset.....
if it still didnt got reset, then you need to remove cmos battery in the board by removing the back cover....
Apr 20, 2010 | Computers & Internet
Bios password ibm thinkpad g40
Sounds like you tried this, but it's worth a shot again. Remove the CMOS battery on the motherboard and let the laptop sit for an hour, then replace the battery with a new one.
If the only real issue is changing the time and date, you can do this in Windows and it will reset the BIOS clock, too, of course.
If the problem is that the time and date keep reseting, you either have a low CMOS battery or a short on the motherboard that is resetting it.
If all else fails, you might need to flash the BIOS from a floppy disk with the latest BIOS version for your machine to reset it and go from there.
PS: BIOS reset problems on laptops are sometimes due to power problems caused by battery packs going bad; check your battery pack, too, and see if it is working okay.
Good luck...
Oct 23, 2007 | IBM ThinkPad G40 Notebook
Toshiba m105 s3004 bios password
i have a Toshiba satellite M105-S322 and all i had to do is open the ram compartment and pull up the plastic sticker or whatever you want to call it between the motherboard and the ram. There is a jumper called "CMOS_CLR1" use a screwdriver to short out the pins and it clears the CMOS.
Aug 24, 2007 | Fujitsu Siemens AMILO D-7830 Notebook
Computers & Internet Logo
427 people viewed this question
David Payne
David Payne
