Error code is L2 and it appears that water does not drain out the water. clothes appears wet and not properly wrung out.
    Sergeant:
    Novelist:
  • 196 Answers
Sounds like You need to clear out the drain pump. You should be able to access the pump from the front bottom by unscrewing and removing the filter. If not then you will need to tilt the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. If it is clear then try removing the pipe that goes from the pump to the base of the tub. Hope this helps
Posted on Apr 06, 2011
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My GE washing machine does not spin the water completely out of clothes. Garments come out very soggy and have to be wrung out by hand before putting them in the dryer. Any ideas?
My washer was pausing during the rinse cycle, sometimes leaving the clothes very wet as well. I pulled out the filter underneath the lower panel, it was packed with coins, etc. Has been running fine (draining) ever since. Hope this helps...
Oct 01, 2009 | GE WSXH208A Front Load Washer
Calypso fails to remove excess water from washed clothings
There are two separate motors, one for the tub and one for the pump. They are both controlled by the motor controller board. Since you say the water drains, the pump appears to be working but since you say the clothes are wet, the spin probably didn't happen. I would suspect the drive motor or the wiring for that motor. There are procedures on the web for testing the wiring and motor windings. Good luck. There is also a pdf diagnostics/test document available. http://www.affordableappliance.com/Download%20Folder/Calypso%20Washer%20Service%20Manual.pdf
Good Luck!
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error Code EO6 - Bosch Front Loader WVT2850
Hi
I have have this same problem for 4 years now and engineers always told me it was becuase something may have been caught in the filter yet I clea my filter weekly and use the decaler they sold me on a monthly basis. Appartantly it is to do with the switch ??
Finally they have written my machine off yippee
Jun 25, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Clothes are still soaking wet after spin cycle
But is the washer empty, if there is still some water in it, there could be something in the drain line,
if all the water is gone, then it sounds like the washer is not reaching the full speed of the spin cycle.
Unless someone can remove the drain line and check the pump, and check the clutch of the machine,
I am sorry to say you should call an appliance person and have them make a service call.
If you where to post the model # of the washer, someone could look at the manual of it and see
how the washer works and what the pump is. I hope it is a simple fix for you.
Mar 21, 2009 | Washing Machines
Clothes were still very wet when cycle completed
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Mar 14, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
I am getting an error code "DC". What does that mean?
DC means: Unbalanced load prevented the washer from
spinning.
This happened to me when i was washing a single shirt (red shirt, first time washing so i did it seperately so it wouldnt bleed into other clothes)
So i set the washer to "drain", waited for the door to open, and wrung the shirt out by hand. Next load it worked properly.
Jan 16, 2009 | Maytag Neptune MAH9700 Front Load Washer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Clothes will not wring out water
On this model, first check your pump for proper operation. Wet clothes can be the result of slow spin speed, which can be casued by a binding tub seal or bearing, brake rotor assy. not disengaging properly, or a slipping clutch spring. You also want to check to see if you have anything binding between the tub and basket that will slow it down. Sometimes a sock or lint can wad up and cause a drag.
May 28, 2006 | Maytag MAV6200 Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
