What is the weight capacity of a Simpson Delta 402 Washing Machine?
    Brigadier General:
  • 6,277 Answers
The information should be on the manufacturer's plate on the back of the machine and in the manual. If you no longer have the manual you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You can also try the manufacturer's web site direct ;-0)
Good luck,
John C.
Posted on Apr 06, 2011
Wash Capacity WF810W
wash capacity?? what is the dry weight?? you meen
did you look at the manual ???
i see its a 7KG machine so 7KG DRY weight
wet weight LOL
what type of water and what did you put in the drum
so its a 7KG machine
so you can put in 7KG of matter to then get wet and get washed
Mar 05, 2015 | Whirlpool Washing Machines
Replacing timer switch on simpson delta s washing machine
Yes it can be replaced. You will need to locate a spares stockist for Simpson machines in your local area or contact Simpson directly in your country.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 27, 2012 | Simpson Washing Machines
Simpson delta 402, I need to remove agitator, how please?
It is a nut on top of agitator you need a special tool
Jul 11, 2011 | Washing Machines
To whom it may concern hello I have bosch washing machine was32794 , 1-can I use bleach?may be it damage the machine? 2-how can I distinguish the weight of cloths is more than the capacity of machine?...
Yes, you can use bleach -- about 1/2 cup oer load -- or more if specified in owner's manual.
The machine could handle easily one full laundry basket -- see below.
  • Capacity of typical Laundry Basket = 6 kg (dry weight)
Calculation: [(36 cm x 51 cm x 26 cm) / 28317 cubic cm] x 3.5 kg = 5.9 kg
Charlie
Feb 23, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Ive taken apart a simpson delta 402 (0036A402P020) and forgot to take note of which side of the pump the black and white wires went to, I am wondering if anyone could tell me the correct placement for...
Hi just read your posting.The 2 wires you mentioned definitely came from the 2 terminals of the pump,Is that correct?Does your fan have a fan attached to it?Now if you have answered yes to both questions then the 2 wires can go to any of the terminals of the pump as it does not matter which way round they go.In other words the wires are interchangeable and it wont change the direction of the pump.Just to be sure, the black wire goes to one terminal and the white wire goes to the other terminal.Hope this helps and please reply to tell me how you got on or if you need further help.
Jun 20, 2010 | Washing Machines
Hi I have a simpson Delta 402 washing machine and it wont drain? I have manually drained it and checked to see if it is blocked at all, and tried to put it only on the drain cycle but nothing works, any...
if u can see the pump has it got a fan attached to it? it should b white or black. if has got a fan try turning it to loosen the object jamming it. if it is firm to turn and it doesnt get loose then u may have to strip the pump.if it has no fan then your pump is a syncro type. please reply with additional information 4 more help.
May 08, 2010 | Washing Machines
My simpson delta 422 fills with water then fails to activate wash cycle
my simpson delta 422 stops on spin dry and i have to do it manualy any suggestions?
Oct 06, 2008 | Washing Machines
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Washing Machines Logo
287 people viewed this question
Top Washing Machines Experts
