Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Hotpoint WF840 wont spin or turn during wash cycle, is it worth fixing or getting a new machine
    Brigadier General:
  • 6,277 Answers
This sounds very much like the belt is broken or the motor is malfunctioning. Whether it's worth getting fixed is difficult for us to comment on; it depends on how happy you are with it when it's working properly, how old it is and how much you are prepared to spend in each case, repair or replace.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though- ours for a 19+ year-old Bosch cost GBP250. It's your choice!
Good luck,
John C
Posted on Apr 06, 2011
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
I have a hotpoint wf840 washing machine (6 years old) and the wash program will not complete the drum turns but will not advance to the end or spin and on the front facia it states f-08 what does tis mean
F08 means you have a heater fault and in this case because the water isnt getting hot the program wont advance. Check out the heater and related wiring. If you dont already know the heater is at the rear of the machine. For more information about error codes go to www.selfix-uk.co.uk
Jan 31, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
I have a hotpoint wf840 everytime i enter a wash cycle it just says test and performs a spin cycle whilst test still comes up on the screen is there anything i can do other than buy a new washing machine
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 05, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Noisy when spinning
bearing gone cheaper to buy a new one
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Our machine wont spin
is there water still in drum? if no it could be motor brushes faulty.
Oct 14, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wf840 displays "test"
Try This - It works for the Washer Dryers so it May work on your Washer.
  1. Press the Start/Cancel button until all the console Led's Illuminate
Hope this Helps.
Mar 12, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
112 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
