Question about Garden
Hi just got a 2nd had victa 4 stroke lawn mower and it wont start. I have right oil in it but after that it stated to leak, interesting thing is it is leaking where the air filter is attached. I have no idea what to do and what to look for. Mohsin
  • 7,482 Answers
Check your fuel filter if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 07, 2011
I have recently been given a Victa Catch and Release Lawnmower,but no manual. How much oil do I put in before commencing use. And How do I drain dirty oil?
Victa catch and mulsh ?
search pops these up as 4 strokes
which model and a internet search gets you its user manual
start with 600 ml oil and top up as required
try not to over fill
look for drain plug up under blades or on the side of motor
Nov 06, 2016 | Garden
What is the victa lawn mower 35 classic a two stroke or a four stroke please.
search on a victa 35 classic makes it 4 stroke
its a brigs and stratton 3.5 engine on aluminum frame + plastic rear catcher
Sep 03, 2016 | Garden
What oil to use for a yardworks gas mower 060-1648, 060-1649, 060-1658
Hi , There's two different types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) Ask at the local lawn mower repair store for the oil type and the 2 stroke grade, it's just two stroke oil you add to the gas (2 stroke mowers ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then NO you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
http://bpretail.bp.nl/australie/2_stroke_brochure.pdf
May 10, 2016 | Garden
What type of oil do I put in?
Hi Shelly, There's two types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) and the 2 stroke grade is just two stroke oil (2 stroke mower ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
Mar 30, 2016 | Garden
Hi I have a brand new Victa Mustang with the Honda GCV160 4 stroke. Hve fuelled up, added oil, turned on fuel tap but it won't start. Any ideas?
Has it been sitting? Has the gas been sitting? I'm sure the carb is all clogged and gummed up with stale gas and dried ethanol. Buy a new carb, GCV160 carbs are like $20 shipped on eBay.
Dec 09, 2014 | Honda Garden
Stupid question I know but is it 4 strock or 2 strock oil for a victa 450 148cc
If there is a place for motor oil on the engine, its a 4 stroke, and use 10w-30. If not, use a 40:1 mixture (gas to 2-stroke oil ratio). Not a stupid question... only stupid if you didn't ask, and did the wrong thing without asking first! Hope this helps!
Oct 20, 2011 | Briggs & Stratton Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
Have a victa lawnmower 4 stroke engine when i started it recently it spits out oil and overheats pretty quickly its only 6 months old. checked oil it was full but i tried to turn it on again the same...
Check that the oil level is not too high, further than that do not do anything. As far as I can remember, Victas have a one year guarantee. Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Apr 07, 2011 | Garden
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
Dec 12, 2010 | Honda Garden
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
