Candy alise GO W 264 D MARCA ERROR E11.QUE SIGNIFICA Y COMO LO SOLUCIONO.GRACIAS
  • 1294 Answers
SOURCE: candy alise 1000 formula stainless
Click on brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Or click on "washing machines" above to find your brand.
Posted on Jan 01, 2008
  • 82 Answers
SOURCE: My washing machine is 15 years old (Candy Alise
there could be afew reasons for you leak but would need to know the quantity things that could be , leaking filler pipes,blocked soap dispencer (fooding) , damage to any pipework leading from drum housing, water pump, or the bearing on the drum if it is baering this would be backed up by the machine becoming genrally more noisy 15 years is a good age
Posted on Jan 17, 2010
Testimonial: "Thanks very much for your help!"
taran_2005
  • 10515 Answers
To start with, 15 years is more than expected life of any washer.I am surprised to see that this washer actually works for 15 years without causing any major problem. However, i am sure that parts would almost be worn out and body being at it's worst. Obviously after 15 years, there is no point of spending many bucks as you see more and more problems with this washer in the next few months.
The real problem in having a leak in your washing machine is that, you can't tell when is it going to leak. They could be leaky in few moments but sometimes it doesn't leak for long time. But if you could give much attention to the washing machine every operation, you could definitely pinpoint where the problem and fix it.
Sometimes the problem could be depended on the type of washing machine you have. If your washing machine is old and top-loading kind of washer, it is easier to be fixed. Because with this kind of washer, the back part is removable and you could see the internal part so it is easy to see and locate where the problem is.
It is very easy in removing the back part just by using a screw driver. If you explore inside the washer, you will realize that it is not that complicated type of machine. But be extra careful in doing this, because if you do it wrong it could cause to flooding and some other bad consequences. Be sure that you will not touch anything inside the control system of the washing machine, because this could electric shock you.
Many washers have screw all over it that would keep you out in the machines internal part. If your washing machine is in that case, the maybe you could open the front corner of it. Then pull the bottom beside the machine. Most of washing machines have easy removable bottom, and then you will be able to see where the problem is and finally fix it.
Always put in your mind that pinpointing the problem is easier when you observe when the machine is operating, so you could see the cycle in each and every step. But sometimes you would miss to see the leak because it only occurs in a different feature.
Locating where the leaks are doesn't mean that you could already fix the problem. It is just the half of the operation. The leaks of the washing machine are usually under the cause of wrong connection of the pipes inside the machine. If you could observe that the pipes aren't piped correctly, then you could fix it easily.
Just look inside your toolbox and look for elbow grease to place the pipes back. In this case, you could also check whether the pipes have any problems. If the pipes are the reason of the leak, then you must replace it or put duct tape or use a trustworthy sealant covering it.
So, you would be able to determine if that is a small issue, use the above procedure to fix it up unless invest in new. There is no point of calling repairman as the cost would be much higher as compared to the cost of the product.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
PS- Do accept my solution,if 100% satisfied from my response.
Posted on Nov 06, 2010
KevinWhite
  • 1902 Answers
SOURCE: my candy alise washer dryer
Hello & Welcome to FixYa
The problem is with the door lock-switch assembly not working, the unit detects that the door is not closed/locked and so will stop in middle of cycle. Please get back to me if you have any other questions.
Kevin
Posted on Jan 09, 2011
19ken55
  • 426 Answers
SOURCE: buenos dias la moto que tengo me marca un error 17
See
Posted on Feb 08, 2011
Lime pro equipment error E05
Pudiste solucionarlo? Tengo el mismo error :S jivera@yahoo.com
Apr 11, 2014 | Lime Pro Equipment D7.3 Treadmill
MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME PODRIAS DECIR POR FAVOR QUE ES ESE ERROR Y COMO LO SOLUCIONO GRACIAS
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
Aug 22, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Check engine que significa ese icono
El icono del motor del cheque significa simplemente que el ordenador del coche ha identificado un problema en alguna parte dentro de uno de los muchos sistemas del coche. Para saber exactamente por qué de que la luz del motor del cheque llegó el tienes que tener el ordenador del coche escaneada. Conduce a la mayoría de cualquier tienda de piezas de automóviles o AAMCO y que van a hacer el análisis de forma gratuita. A continuación, le dirá lo que su equipo es informar a usted como un problema. Regards, Joe
PS favor y amablemente tasa de mi respuesta. Gracias.
Jan 21, 2010 | 1995 Jeep Grand Cherokee
Que significa cuando enciende la luz OD/OFF es un sensor o es problema de trasmicion
es posible que es una problema de transmicion. es posible que es el interruptor de OD/OFF tambien. si Ud empuje el boton y la luz no se apgaue pero no aye otros problemas, creo que es probablament el interruptor.
Oct 09, 2009 | 1999 Ford Expedition
Luis
el problema es que no tengo los driver de sonido de salida de audio
qure usted que me los podria proporcionar de gratis
Oct 03, 2008 | Computers & Internet
Washing Machines Logo
852 people viewed this question
Top Washing Machines Experts
