Question about Canon PIXMA MP460 All-In-One InkJet Printer
How do you align cartridge head??? - Canon PIXMA MP460 All-In-One InkJet Printer
  • 310 Answers
You align the print head like that :
1.go to printer and faxes
2.rigth click on the printer
3.properties
4.then you go on maintenance and pick print head alignment
If i have been useful please give me a vote :).Thanks
Posted on Apr 06, 2011
Testimonial: "total useful and simple instructions so i can follow"
Do i need to align print head?
as the print heads are disturbed when changing cartridges and no two cartridges are exact
it is always a good idea to do the alignment after installing new cartridges
Feb 08, 2017 | Office Equipment & Supplies
Says problem with alignment. Remove tape from cartridge or check troubleshooting. There is no tape on cartridge so what should I do?
It may mean the print head alignment rather than the cartridge
Check properties on printer in control panel and see if there is a head alignment option.
If there is it will print out an alignment page that you can compare to see if alignment is out on the print head.
Try also Google search engine
printer model and print head alignment
Dec 05, 2016 | Office Equipment & Supplies
Unable to align Epson 3540 print heads
Hi, it is possible that the cartridge/s are not seated properly.
Try and remove them and reposition them again.
Sometimes this will work.
Also try turning the printer off and unplug it for a short time then retry installing the cartridges again.
then do a realine and see if it helps.
Regards Micky
Dec 12, 2013 | Office Equipment & Supplies
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
Hp 8500 printer stuck in continuous cleaning and alignment loop after replacing cartridge
Printer wont do the alignment process if we replaced the cartridges, might be removed/re inserted the printer heads, then ply it process the alignment, if the print head nozzles are clogged, alignment process wont completes..
>Remove the print heads clean the nozzles with tissue paper gently at nozzles.
>borwse this link & see how to clean the print head,link:http://www.youtube.com/watch?v=ZAwYIbjswV0&feature=related
>Install the printer heads do the alignment..
> if not completed check which printer head clogged, replace the print head.
Oct 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Printer reads no cartridge when one is in
Hello
Remove the ink cartridge (or cartridges) from the printer.
Turn the cartridges over so you can see the copper foil portion of the cartridge casing. You'll see many neatly punched holes in this copper tape. Look closely: if any of the holes seem to be torn, with jagged edges, or if there are tears anywhere else on the copper foil, the cartridge has been physically damaged. Replace it. If the foil appears to be all right, continue.
Moisten the tip of your finger. Gently rub it over the small print head on the bottom of the cartridge. The print head will look like a small plastic or glass window. Rub away any old, dried ink that may have collected on the print head. Old, dried ink has "killed" many a cartridge, particularly if you haven't used the printer in a while. Use your finger tip rather than a towel or a cotton swab: Your fingertip won't leave stray fibers on the print head which could cause further problems.
Seat the cartridges back into the printer. Firmly snap shut the cartridge carrier. Let the printer take the cartridge head back to the proper starting position on the track. Close your printer service bay.
Turn off your printer. Unplug it from the power source for 10 seconds. Plug it back in and turn on the printer.
Follow your onscreeen software instructions on aligning the cartridge heads. The alignment prompt comes up each time the printer detects the cartridge has been replaced or moved. Be sure to note whether this is a new or an old cartridge when you answer the dialog questions.
Use a brand new cartridge, one that is freshly packaged, if the alignment process on the old cartridge fails. This will tell you, definitely, whether the problem is a cartridge problem or a larger printer problem.
Replace the printer if no cartridge--regardless of age-- will successfully align in the printer.
Oct 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
Changed cartridge--now paper gets stops by cartridge carrier. turned on and off, reinstalled cartridge, cleaned roller.
Press the OK button.
- If paper is being fed at error occurrence, the
error is indicated after the paper is ejected.
- If the error occurs, the print head alignment
values are not changed.
- After exit from the error by the OK button,
the automatic print head alignment will not
be re-done.
The error will occur when the print head
alignment pattern is not printed due to no ink
or non-ejection of ink.
Oct 11, 2009 | Canon PIXMA iP1800 Photo Printer
In case of misprint please align head
Someone has removed a cartridge and reinstalled without doing a head alignment.
Do a head align every time a cartridge is replaced or taken from holder.
Aug 14, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
214 people viewed this question
old marine
old marine
