Question about Boss Micro BR Digital Recorder
Br900cd unable to remain switch on - Boss Micro BR Digital Recorder
  • Boss Master
  • 5,603 Answers
Check power source or batteries. This unit will go through batteries fairly fast and when low the unit will not stay on. You CANNOT use rechargeable types as they have lower voltage and they quickly fail and shut off. Check the voltage out of the adapter if you are using one..
Posted on Apr 06, 2011
Why am I unable to switch off with pedal?
The switch probably needs to be replaced. However, look into the cost to repair this first. It may be cheaper to just replace the whole pedal.
Mar 04, 2016 | Behringer Bch100 Bass Chorus Pedal Make...
Faders not working on BR900CD drum machine
I would suggest updating to the latest software first to see if that solves it.
BR 900CD Downloads Support Roland
If not, contact Roland Support for suggestions or the name of your nearest Roland repair center
Customer Service can be reached at 323-890-3700 x 7005.
They are available Monday through Friday between the hours of 8:30am and 5:00pm Pacific Standard time.
Feb 28, 2015 | Music
Boss br900cd factory defaults re install
Here is the newest updates for it, http://www.bossus.com/gear/productdetails.php?ProductId=718
1. Press [UTILITY].
2. Press CURSOR [ ] [ ] to move the cursor to "INI,"
and press [ENTER].
3. Press PARAMETER CURSOR [ ] [ ] to move the
cursor to "ALL," and press [ENTER].
The confirmation message "Are you sure?" appears in
the display.
4. To continue the initialization, press [ENTER] (YES).
To cancel, press [EXIT] (NO) (or [UTILITY]).
When [ENTER] is pressed, initialization begins.
After the initialization has been completed, you are
returned to the Play screen.
You can perform the same initialization with "INIT
ALL," by holding down INPUT SELECT [GUITAR/
BASS/MIC2], [MIC], and [LINE] while turning the
POWER switch ON, then pressing [ENTER].
Mar 03, 2013 | Roland Boss BR900CD Digital Recording...
It just wont turn on, and i'v tried other power supplies that deffinately work and it still wont. help!
Use the correct PSC power adapter. 9 volts, 1 amp... not sure of the polarity... searched all over for the spec. The unit draws 900ma so you need a 1 amp supply. Most "universal" supplies will not provide enough current. If you have tried the wrong polarity you may have damaged the unit.
Sep 14, 2011 | Roland Boss BR900CD Digital Recording...
My Utility button is not working right. It started to slowly become harder and harder to pull up my utility menu and now it doesn't work at all. I want to take the face off and try to clean it or see...
We have no way to send diagrams on this service itself. If you are careful you can usually remove screws around the outside edge and gently open the units... ALSO look for screws in "wells" in the central portion of the back... ONCE YOU get inside, expect to find this: There will be a circuit board attached to the faceplate that has your switch on it... EXPECT to have to remove all the slider knobs (pull off nice and straight)... possibly you have to coax the rotary control knob(s) off. There will be a few screws mounting the circuit board to the face as well. I am not sure exactly what type of switch you will find under the offending button, so be prepared to remove it, search suppliers like Digikey and Mouser, etc. for a replacement and wait a few days for delivery. Use a little organizer to keep parts in when disassembling. Be VERY careful of ribbon cables when disassembling. The switches in certain functions take a lot of abuse and excess pressure on them can damage the mechanisms. Also they are switched "dry" meaning there isn't enough current drawn to keep oxides off the contacts.
May 04, 2011 | Roland Boss BR900CD Digital Recording...
Hi. I really hope you can help me. No one else have so far! This is my problem: When I connect with USB to my computer my Boss BR900cd hangs, and the only way tp turn it off is by using the main switch....
See if unplugging the USB will then allow it to turn off... If it does, likely the USB is backfeeding enough to keep the power circuit alive. It is possible also that the software on the PC needs to close as they may have an interlock that prevents one from dumping power if PC is still connected... Just some thoughts on possible reason for the symptom.
Mar 16, 2011 | Boss Micro BR Digital Recorder
Downloaded version 2 to my br900cd now one of my flashcards that i had several songs on will not load message saying unsupported card
Don't you just hate these incompatibility issues?
Try the VSPLANET.com site where a lot is discussed about the Roland (Boss) recorders.
May 13, 2010 | Boss Micro BR Digital Recorder
Sounds like a version compatibility problem.
Check with the folks over at VSPLANET.com where Roland digital recorders are discussed in the forums.
Mar 22, 2010 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
54 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Darial Jr Lasaria
Darial Jr Lasaria
Vito Vacirca Jr.
Are you a Boss Music Expert? Answer questions, earn points and help others
