Question about Wahl 8550
WAHL class 2 transformer.inpot 230v-59 Hz 13 W . output 3.0 v dc 1.8a. to use with wahl clipper model.9551-8554 or8745 only.
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
SOURCE: reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
SOURCE: how to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Posted on Dec 04, 2009
SOURCE: WAHL model MC. Very loud (mechanical)
Should have a flat head screwdriver handy... on the side of the clipper there is a dial where you can insert the tip of the flat head.. Turn on the clippers and turn that knob with the screwdriver slowly till it hums nice and even..
Posted on Nov 17, 2010
I'm going to Italy. Is it dual voltage?
Italy uses 220 volts, 50 cycles alternating current (AC). If your appliance works on both 110 or 220 then IT'S dual voltage and should work. If it only runs on 110 then you will need a voltage converter to use it on 220.
Dec 03, 2015 | Wahl 8081
Replacement filter for KM2
Contact your nearest Wahl agency www.wahl.com
Oct 29, 2012 | Wahl Two Speed Dog Grooming Clippers Km2...
How do I use Wahl hair clippers? How do I know
Hi I have been a hair stylist for 25 years each guard that clips on has a number on them the lower the number the more hair is clipper off start big like a number 8 will leave one inch of hair 7 leaves 7/8 of a inch 6 leaves 3/4 of a inch 5 leaves 5/8 of a inch 4 leaves a 1/2 inch of hair on the head 3 leaves 3/8 of a inch 2 leaves 1/4 of a inch and a 1 is just hair on the Scalp almost bald no days the color of guards are changing so your best bet is go with the size remember to start with the largest one first then you will know what you like the best and you can't go wrong and if you buy WAHL and you not A Hair Stylist You Can Purchase A Good Clipper at Sallys Good Luck
Jul 30, 2011 | Wahl Health & Beauty
The wahl peanut has the same motor than wahl tid bit?
the tid bit and the peanut are the same clipper. you will find the tid bit clipper at shaveroutlet.com. See link below
http://shaveroutlet.com/wahl-tid-bit-professional-compact-clipper-trimmer.html
Jun 22, 2010 | Wahl 8685 Hair Trimmer
Where can I buy attachments for Wahl Super Taper Hair trimmer. Full kit or just No 3?
Manny's Sharpening has the Wahl attachment for $3.00 ea any size from 1/2" to No 9 323 263-4697
Mar 08, 2010 | Wahl Super Taper Hair Clipper 2000 Hair...
I have a Wahl clipper Pro Series Rechargeable model 9550 and can't figure out which charger goes to it. I have one labled for model 5550 only - is that it?
My clipper, model 8552 says use with model PCC charger only.
On the charger / transformer it lists the clipper models it will work with. It says class 2 transformer model A30316Q then lists the models in the middle of the unit and then at the bottom says model PCC PT#97562-103
Mar 06, 2010 | Wahl 8550
Have lost charger and battery number for model number9918 please help
from the picture you have here, That I see you have a Wahl 8554 Wahl Alpha cordless clipper. but you stated the model 9918-6171 Groomsman Beard and Mustache Trimmer model, You need to be sure of what model you have. He are the two picture of each model. if this is correct, Mannys Sharpening has the charger for this cordless clipper, I had the same problem and he sent me one it took about 2 weeks for delivery.
27a92b7.jpgThe clipper on your Left is Wahl 9918
3283d36.jpg This clipper is the Wahl Alpa 8554 cordless
Call Mannys Sharpening he has all the replacement charger for Wahl.
323 263-4697
Jul 28, 2009 | Wahl 8554 Hair Trimmer
Wahl 8550 Logo
181 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
