It is possible that the Welger 435 Master baler may have a plate located between the back end and the axle to aid in the discharge of bales. This plate, which is sometimes called a bale ramp or a bale slide, is designed to allow bales to be more easily loaded onto a trailer or other transport vehicle by providing a sloping surface for the bales to roll down.
To confirm if your Welger 435 Master baler has a bale ramp or slide, you can check the owner's manual or consult the manufacturer. You can also inspect the baler itself to see if there is a plate or ramp located between the back end and the axle. If you are unable to locate the bale ramp or if you are unsure if your baler is equipped with one, it is recommended to consult a mechanic or the manufacturer for further assistance.
A standard PS2 to USB cable will not work with these scanners. You'll need to purchase cable # M009-3MA7C. They are expensive, so shop around for price.
Hello Sir,
You Can get the Argox Printer Driver From the below mentioned site
http://www.argox.com/content.php?sno=0000033&P_ID=22
If you need help with Barcode Printer Sales/Service.
Call Trridev labelss Mfg Co
Manufactures of Self Adhesive Labels
Resellers Of Barcode Printer and Barcode Scanner And Thermal Ribbons.
Reach us at 044-24543123 / 96000 07995
For more information, visit our web page.
I would exclude a laser problem. It looks like this is a cable problem instead.
First check if the TV cable is well plugged both to PS2 and TV.
Second, the cable could have been damaged while you were moving the TV, if you don't get results with the above solution, i'd suggest to get a new one at a local retailer, a PS2 RGB cable will cost just few bucks, but before buying something, I'd try the PS2 on a second TV, if have the chance.
Good Luck!
Peter
For future reference, the cable is easily detached by inserting the straight end of a paper clip into the pinhole at the bottom of the handle where the cable attaches.
I would not recommend attempting to repair this device yourself. You could cause more damage than you already have. Since the device has a 5 year warranty, it may still be under warranty. The charge for reconnecting everything, if there is no damage, should be minimal.
please find the manual in the following url: it's in the pdf format, http://www.compextec.com.br/download.php?dir=dXBsb2Fk&download=Mi8yNzUucGRm&tipo=2&nome_arq=All%20Argox%20Scanner%20Manual.pdf&PHPSESSID=6a823c9424dab5271768c4177468adbd
