When I turn on my toshiba laptop, it turns up for 5 seconds witth some bips and without coming anything on the screen it turns off by itself . What should I do?
  • 34 Answers
Try first to turn on the pc and tap the F8 key. This will launch the Advance Menu options. Try to choose Safemode with Networking. If you were successful going to Safemode with Netwoking, try to backup your files using a usb drive. Having those beep codes could be a hardware failure already.
Posted on Apr 06, 2011
I have a problem with my toshiba L300 the screen does not come and the keep restarting without displaying anything ont he screen .
Welcome to FixYa!
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
May 15, 2011 | Toshiba Computers & Internet
TOSHIBA SATELLITE M55-S3512 LAPTOP LCD SCREEN is red then it switches off. When I close and reopen the lid the screen turns on for 3 secondes then goes off. Do I need to change the lcd?
hi,
Please try to remove the battery and the AC adapter then press and hold the power button or the on/off button for one minute. Basically,it will not turn on since there is no power supply connected. After one minute, connect the laptop directly to the power outlet without using the battery just for the meantime then power on the laptop, if this will not fixed the problem, you will need to replaced the LCD cable or the LCD itself.
Hope this will help...
Jan 08, 2011 | Toshiba SATELLITE K000080220 LAPTOP LCD...
When i start it, his fan turns while a few second and stop, nothing is happening neither the screen doesn´t display or bip. what can i do
This may well be a fault with your RAM, CPU or system board. Check the RAM is inserted properly, if two modules are installed try removing them one at a time and see if it helps.
Hope this helps, www.PuterCare.com
Jul 02, 2010 | Toshiba Satellite P205-S6287 Notebook PC
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Why the screen of x205-sli1 off when power on?
If there are 3 beeps when you power on, most probable it is because of the memory.
Steps for Troubleshooting
Note:remove any source of power first ...
1. Try removing the memory
2. Clean the memory using a white pencil eraser
3. Boot up the laptop without the memory
- You will hear a beep not like the 3 beeps you heard.
4. Turn off the computer again and put back the memory.
5. Then try booting up again.
Hope it helps.
Jan 10, 2010 | Toshiba Satellite X205-S9349 Notebook
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
My ps3 turns on but nothing comes up just blank screen if i hold the power button on the front for 5 sec the screen will flash and then blank screen
to reset the video settings you have to turn the main switch on the back of the ps3 then place your finger in the on sensor in front of the unit with your finger there turn the main power switch on the back of the unit the playstation turns on keep your finger there until you heard one bip and then remove your finger from the on sensor before the unit turns off if you keep your finger there for too long it will shuft off the unit so remove your finger once you heard the first bip and wait about 40 to 50 seconds some playstations take that long to restart after resetting the video card if this do no work try few times but if still not working then your graphics card is bad and sorry it can't be replaced
Mar 12, 2009 | Sony Playstation 3 (PS3) Console
Toshiba Satellite turn ON problem.
Remove the battery and then try to run your laptop direct from the mains supply, if this works it proves your battery is NFG and you need another.
Mark
Oct 16, 2007 | Toshiba Satellite M30X Notebook
Computers & Internet Logo
David Payne
David Payne
