I have a imedia x2415 quard core tower system and it will not switch on unless i unplug the cpu lead from the mother board
  • 2 more comments
  • Brian Sullivan
    Brian Sullivan Apr 06, 2011
    are you sure if you unplug the lead shouldnt it turn OFF
  • kpredator Apr 06, 2011
    i mean it stays on not boot up
    i have already changed the psu when i press the button to boot the computer up it comes on for a second then turns off
  • NOpris Feb 29, 2012
    hey @kpredator - I just got this same problem now - my pc started freezing and now won't start with same simptoms as yours. If I remove the CPU power (which is a separate cable with 4 wires) the fans will stay on but nothing shows up on the monitor.(obviously) Any idea how you fixed it? I removed the cdrom and hdd leads so i should be able to see the bios at least...but no luck
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 06, 2011
  • Brian Sullivan
    troubleshooting a computer
    the next thing to test are the leads
Is it possible to upgrade the mother board in this computer?
Dell Cases are very often only for Dell boards--connectors not standard--It can be done,but a lot of trouble. If you want to really speed up look for good complete kit from tigerdirect.com--and put it together--Will work A LOT better than what you can buy at stores.
Jan 31, 2014 | Dell Precision 390 Workstation Tower,...
I purchased a set of Logitech LS21 speekers and I can' get them to work. Below is a list of my system hardware and the steps I have done so far. Motherboard is a Gigabyte GA-MA785GM-US2H 16GB RAM AMD...
Go into control panel, then go to device manager and see Audio devices. Check to see if your Realtek is listed as your default audio device. If it isn't you have to add hardware and add the audio device using your setup disk that should of came with the computer. If the audio device is set up and working in device manager then check your cable from the mother board to the jack on the audio out that is mounted on the mother board. Finally if non of that works see if you can borrow a set of speakers to try to see if they work with your setup.
Mar 07, 2011 | Logitech LS-21 2.1 Speakers
Hi i have a imedia desktop, the mobo is a msi 7168 ,( socket 939) the origional cpu is a amd athlon 3200 single core ! now i have replaced this with a dual core athlon 4400+ now the memory has 4 dimm...
First time I heard that But Maybe your board needs a bios update which I personally wouldn't do unless you really know what your doing. I would buy better ram and more of it and just use the two slots that work.
Jan 24, 2011 | AMD (90613) PC Desktop
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
My mother board DG41RQ is not detecting any hard disk drive
Here are two locations in delhi;
Upper Ground Fl, Block E
Int'l Trade Tower, Nehru Place
New Delhi
Delhi 110 019
India
21 Nehru Place, Suite 311
Paharpur Business Centre
New Delhi
Delhi 110 019
India
Jan 27, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
Power connections for tower led's
The manual in question can be located here
http://download.intel.com/support/motherboards/desktop/sb/d1047103_en.pdf
It is a pdf file, so you will need ADOBE,
I have checked and the pinout for the front panel connectors is there.
May 24, 2009 | Intel D945GTP Motherboard
Computer is not functioning
H!
Please check the lock of your processor. If it is tight or loose. If it is loose then it is the one causing the mother board no to function properly. You must tighten it to make it stable. After checking and it is not the reason for the malfunctioning of the system. Try to remove your CMOS battery and then clean, and remove also your memory card in the mother board and clean. Return it after cleaning and then close the CPU and turn it on. During the booting process strike the delete key to enter into bios set up. Adjust the time/ date settings to your current time. Press F10 then enter. wait for the CPU to process.
Please post any comment if it was solve so that I can give you more option if it does not solve your problem.
jonags3
Apr 17, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
No sond on my speakers
does computer work start up ok with new cpu did u do fresh formatt install when u install new cpu u should formatt it al redo xp on it also u need more ram 256mb way low least 512 mb more ok if u need help and beat prices im open for live chat thx nick helpap
Jan 06, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
New Problem
The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
Aug 15, 2007 | Balance CP4401 PC Desktop
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
