My new laptop see the toshiba sata mk1646gsx from my old -damaged- laptop but i can't use it when i connect it by USP conection, because it has password, how can i use my old hard didk
  • 32,281 Answers
Your old hard disk may have been password protected (it may have the same BIOS password that was used on your old laptop). To access the data on the old hard drive, enter the hard disk password and if it is correct, you will get access to the data on the old hard drive.
Posted on Apr 06, 2011
Need help with a error f3f2000002 on my toshiba
That is a fatal hard drive error, possibly damaged sectors. Purchase a new hard drive and install your OS then using a usb sata connector from fleabay, copy what you can from your old drive back to your new drive.
Hope that helps to recover some or all of your data.
Dec 22, 2013 | Computers & Internet
Toshiba mk1646gsx
your laptop hard disc is about to crash,back up your data somewhere like on another computer, by a new hard disc, fix it in your laptop and install operating system on it
Aug 21, 2013 | Computers & Internet
Password fot toshiba mk1646gsx, hdd serial number 48buffg7s ?
The security password was set by the user. Ask the user who set it for the code.
Oct 26, 2012 | Toshiba Computers & Internet
Hello i am trying to connect my copier to my laptop can you tech me how to do this step by step
1- you need to download drive up to your sys windows & a dongle "USP software "
2- www.estudio.com.sg/download_monochrome_more.aspx
3- use USP cable or better to use a network cable to connect.
4- setup the drive & use usp to copy or setup network ip for the copier & another for computer" making a small lan network "
Jun 14, 2011 | Toshiba e-Studio 350 Copier
My toshiba HDD (Model-MK3265GSX) Serial Nunmbet 40LDF2NIS KK 8 EC . A has failed. It is not readable from outside. In order to recover the data, I need another good Toshiba HDD with a serial number close...
If the drive has failed then the only option to recover data is to send it to a data recovery service but these are not cheap.
Installing another drive with a close batch/serail number will not allow you to copy from a dead drive.
I would be connecting to a regular desktop computer and trying some of the free data recovery software available such as hirens boot cd.
ANY drive within the max and type supported could be used in your laptop.
Thses are common problems with laptops and in most cases I recover data (when the drive is not too damaged) as i described above.
I then install a new and often larger drive and build the system from the recovery CD's available from the laptop manufacturer.
Then old transfer any old data I recovered back to a folder on the new drive so that customers have access to anything that was saved.
The only sure way of getting everything back from a damaged drive is to send it off but that is only of use to you if your data is mission critical.
I use the cheap USB to IDE/SATA adaptors often available from good computer shops.
Feb 15, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Putting damaged hard drive into new laptop
Have you considered an external case for your old hard drive? These can be found at newegg and tiger direct. I have successfully gotten data off of some old laptop drives this way. Hopefully your drive was/is not encrypted or this solution will probably not work.
In order to know if the drives will fit you would have to look up the specifications for both laptops. Look to see if they are both the same as far as hard drive size (2.5, etc), connector (IDE or SATA). One problem you will encounter just swapping out the drives is that there will be new hardware in the new computer and Windows sometimes reacts badly to a big change in system components. Sometimes it will blue screen, sometimes it will ask you to reregister and boot up, but even then you can have problems. Hopefully this helps some.
May 04, 2009 | Computers & Internet
Hi, I have a Toshiba Satalite Pro U300 laptop and my CD/DVD drive will not read discs (TOSHIBA MK1646GSX).
did you tried yet to reinstall the aspi32 package from adaptec?
http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi32_exe.htm
4 files are coming out of this autoextractible archive..
ensure, you delete the old one present in the system and replacing by these,
verify the version number of each to ensure the process of aspi driver reset
Nov 20, 2008 | Toshiba Computers & Internet
Hard Disk Toshiba MK1646GSX
Change setting to SATA as this is a sata/300 drive.
Jul 10, 2008 | Computers & Internet
Fantom Titanium Hard Drive - 500GB
You can remove the drive from the casing and connect it inside your pc, using IDE cables if its an IDE or a SATA cable, if it comes with one
Dec 26, 2007 | Fantom Titanium Hard Drive
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
