When I want toconnect my device to bluetooth the window bluetooth settings allways reports an error occured I am kindly asking for help Toshiba Portege R700-L14 Bluetooth stack version 8.00.02(T) Windows 7 64bit
  • 2,574 Answers
Remove/Uninstall your bluetooth software driver ..and install this version ..click here
If you select [ Run ] ( or [ Open ] ) instead of [ Save ],the file will be automatically installed after it is saved. The downloaded file will be saved in the specified place inthe self-extracting form ( .exe format ).Double-click the downloaded EXE file to decompress it,then installation will start automatically.
Posted on Apr 06, 2011
Windows has stopped this device because it has reported problems. (Code 43). THis error message is coming while connecting bluetooth dongle to my toshiba laptop windows 7 64bit plateform
Try this, diconnect Laptop from power source ie Remove the battery. Unplug your bluetooth dongle from the Laptop. Reinsert the battery back to your laptop after about 30 sec. Restart your laptop & insert the dongle.
Hope it fix your problems.
Dec 02, 2010 | Microsoft Windows Vista Ultimate Edition
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
I get a report message saying basically this : An Error occured during installation.The driver installation files for this device is missing a necessary entry. This may be because the INF was written for...
Yes,
 you need a Vista driver for this device, windows 95 shows how old it is !
If you are upgrading from WIndows XP to Vista delete all the mouse drivers in the device manager (under control panel).
Then let Vista install new ones.
Mar 07, 2010 | Toshiba Black/Red USB Laser Mini...
My Bluetooth won't let me turn on Discovery. When I pute a tick in the tick box for ''Allow Bluetooth Devices to find this Computer'' It says ''An error occured while windows was saving your...
you will need the correct bluetooth driver for VISA.
from HP is best.
if HP devices.
if not HP device, you never said bluetooth what, head phones, keyboard, mice, wireless, what? IS IT.
if non HP you need to read the pages of the DEVICE
not stated.
find the vista driver, gee some makers dont support vista...
fact.
Jun 11, 2017 | HP Computers & Internet
How do i set up bluetooth on my pc?
Hello!
First you need to turn on the wireless switch. Next, if you want to do pairing (sync with another device), you should turn the blue-tooth on the other device.
Then right click on the blue-tooth icon on the system tray (near desktop clock), then select "Add a blue-tooth device", now check the box "my device is ready to be found", then click "next".
Your laptop will find the other device (sometimes you need to try a couple of times). After that it may ask you for a password. You can type e.g "1" on your device. You'll also be asked same on the other device, use same password.
Now pairing has been done & you can send files to & from other device.
Sometimes you need to right-click on the blue-tooth icon & click receive a file.
please send us your vote & feedback. Bye
Feb 21, 2010 | Toshiba Satellite L25-S1193 notebook
Failed Web Camera Installtion
FIRST INSTALL THE SOFTWARE(cd)THEN INSTALL HARWARE
Jun 05, 2008 | Computers & Internet
Reinstall the driver, or uninstall the driver and do a fresh install with the correct drivers, check if the usb2.0 drivers are installed.
Jan 08, 2008 | Toshiba Satellite A135-S2276 Notebook
Conecting Blue tooth phone to acer laptop
has your model actually got bluetooth built in as most Acer laptops have the switch, but do not have it fitted, if you do check in control panel> device manager and see if it reports any problems by way of an exclamation mark. You will probably have to purchase a bluetooth usb dongle for about £9.00 or $18 US and use that
Sep 14, 2007 | Computers & Internet
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
