I m not be able to get proper resolution of my laptop
  • nmkashyap Apr 06, 2011
    i had already through with ur solution even then there is no change in my laptop resolution
    and if more over u can help my anything then i am giving u my laptop model is lenovo g530 model
    Scholar:
  • 118 Answers
Check on the manufacturer's website what the default resolution of your laptop model is.
right click on desktop, -> properties -> settings -> screen resolution.
sometimes if you have an advanced graphics card/controller it can detect the ideal resolution for you.
Posted on Apr 06, 2011
Aspire 6930 HDMI output shows only part of picture. Used to work correctly.
change the settings in the display adaptor for the HMDI. They may also be accessible in the display icon of the control panel.
Oct 06, 2014 | Acer Aspire 6930-6771 Laptop
Screen flashes colors
The issue (flashes" colored screens) you're facing could be related to drivers and could be resolved by updating the display drivers. Without the correct driver, the hardware or device that you want to use won't work properly.
Also refer to:
http://windows.microsoft.com/en-us/windows7/update-a-driver-for-hardware-that-isnt-working-properly
Let's try to boot the computer in low resolution mode and check the issue status.
Low resolution starts Windows using your current video driver and using low resolution and refresh rate settings. You can use this mode to reset your display settings.
Refer the section:
Enable low-resolution video (640×480)
Apr 24, 2014 | Microsoft Inspiron Notebook
Projector Image Cut Off, Native Resolution Not Recognized by PC
after you connect the laptop and the image shifts to the right, press auto adjust on the remote and the image will get OK.
If not try resetting the projector settings to factory [not the lamp settings]
this should solve the problem
if not change the main board
Jan 15, 2013 | Panasonic PT-AE900U Multimedia Projector
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
I have a Toshiba Laptop and the keys are not working properly. When I press shift 2, the symbol " is shown and I can only get @ by pressing alt button along with ctrl and 2. please help. same goes...
your laptop needs service by a qualified tech
1. it seems that you have possibly a keypad controller or a loose keypad cable which will require disassembling the laptop.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for your issue.
Thank you.
Jun 14, 2011 | Toshiba Tecra A9-S9012X Notebook
Work find with everything but laptop
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for you Problem
Thank you.Fixya expert
Mar 13, 2011 | HP Compaq nc6120 Notebook
How can I use my plasma tv as a monitor so I can connect my laptop computor
Assuming your laptop has an S Video output you would connect it to the S Video input of the television with an S video cable. Before doing so you should have turned the resolution on your laptop down as far as it will go. I believe the proper S Video resolution is 640 x 480. You can find an extensive resolutions list here http://en.wikipedia.org/wiki/List_of_common_resolutions
After setting the laptop at the resolution you're going to try you should turn it off (not restart it; actually turn it off). Now connect the S Video cable between the television and the laptop and turn the television on first before the laptop. Turn the laptop on and switch the television to the proper video input. Hold down the function (fn) button on the laptop and the dual monitor key (usually f5 or f8) for about 15 seconds or longer until you get an image on the television screen.
Sep 28, 2010 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Everything on the screen appears stretched
If you can, set the Screen resolution to the maximum native resolution your monitor supports by adjusting the slider. to 1680x1050, if you can set it to that, then Windows will automatically display at the proper aspect ratio, and the monitor will not have to stretch anything. Setting your screen resolution to match your monitor's native resolution is, by far, the preferred solution to get you the best looking display.
If that specific resolution is not available, then you'll need to try resolutions that are smaller than that, but ideally with the same aspect ratio. 1512x945, for example, would maintain the same aspect ratio. Not all monitors handle running at less than their optimal resolution well, and it may result in a slightly fuzzy display, but it won't be horizontally stretched. If this fails to fix the problem it could be a problem with your video card
Jan 03, 2010 | Computers & Internet
I need the service mode sequence for my philips 51pp9100d/37 so I can manually change the resolution on my tv. The resolution somehow was changed and when I HDMI my laptop to the tv it wont display t
I suspect that you may be using a cable or sat box rather than that set's internal atsc tuner.
Sometimes these boxes are not set up properly or reset themselves to a lower resolution.
Go into your box's settings menu nd look for the resolution settings. Verify that all of the modes or at least the maximum resolution for your set is enabled.
May 02, 2009 | Televison & Video
Hp w1907 monitor on start up shows the wrong resolution
Have you tried adjusting the resolution to the prefered resolution, than shutting it down properly.
(Not pressing off button, or if laptop closing screen,
Contact me if this does not work,
Regards,
Asitomani
Feb 10, 2009 | HP w1907 LCD Monitor
Computers & Internet Logo
David Payne
David Payne
