Question about Acer Aspire™ T180 PC Desktop
Printer sharing I am trying to set up printer sharing using one PC in a small network as a print server. I have 2 printers connected to the usb ports on this pc but cannot print to these 2 printers from the otherPC's in the ethernet/IP network. I think I need to indicate the "path" but I'm not getting it right. Can you help? thanks brian
  • thomaas Aug 18, 2008
    Thanks for the prompt reply and the information was most helpful - I can now print from all PC's to the server printers. I only have one small problem .......
    Printing from the PC's that are independent of the server PC is very slow - even clicking on the properties of any particular printer takes several mins to open and when I click on "print test page" (and all printing) it will also take several mins to print. If I open properties and print a test page from the actual print server PC the speed is normal - prints staight away.
    I am using vista home basic 32.
    thanks
    Genius:
  • 1,056 Answers
This is assuming you are using Windows XP.
On the PC that will print to them, go to Printers and Faxes, open the window with them, right click and choose Sharing and Security
Click on the tab that says Sharing, and click the dot in "Share this printer"
Give it a simple name (like Laser1 or Inkjet1)
Click OK, and close the window.
On the other computers that you want to print to it, open My Network Places, Entire network, MS Windows network, <your workgroups name> **it works best if all of the computers in your network are part of the same workgroup**, look for the computer that is hosting the printers, double click it.
You will see the sharde printer name below the computer, right click on the printer and choose "Connect" say yes to the question that comes up about the connection security. When the flashlight goes out, you're connected.
Remember, for it to be a print server, that PC must be on.
Posted on Aug 06, 2008
  • Coss Aug 18, 2008
    Ok, couple of questions then.
    What kind of printer?
    What are the stats of the host PC? (memory, CPU etc)
    How are all of the PC connected? (wired connection, wireless. etc).
    You did say that the host PC was Vista Home, which is not the best networking platform (it has some serious flaws in network sharing), and that's probably the cause for the lag in printing.
    If you have a machine that is running XP Pro, or Vista Business, or Vista Ultimate, you'll probably get rid of the lag.
    In a situation like this, I would lean towards doing teh independent print server for the printer. That way it is not dependent on the network hosting services of Vista Home.
    Here's an example of an independent print server
    Wired to parellel port
    http://www.netgear.com/Products/PrintSer...
    Wired to USB port
    Wireless
    http://www.tigerdirect.com/applications/...
How to make a printer wireless
Plug into a wireless print server.If your printer has a USB port, you can plug in a wireless print server, a small box into which you can connect your printer. The advantage of investing in a print server is that you don't have to connect the printer to a PC, which means you can use your laptop and print anywhere in your home.
.tmnAdsenseContainer{margin-bottom:10px;} We found plenty of print servers in the $50 range on Newegg.com, although many of the models cost closer to $75 or $100). Before you buy, make sure the print server is compatible with your printer (the printer's written materials are less likely to specify compatibility with print servers).
During the setup, you will have to plug the printer into the printer server, and connect that to the router using an Ethernet cable. Meanwhile, you'll have to install software on your computer and configure the connection, as you would when setting up a router.
also try this link will help you
http://www.makeuseof.com/tag/printer-wireless/http://www.ehow.com/how_4530941_make-printer-wireless.html
http://www.labnol.org/gadgets/make-wired-printer-wireless/12639/
Dec 27, 2012 | Samsung Office Equipment & Supplies
Tip
Network Connected Printer Not Printing
TCP/IP Lan
Network Printer...this does not apply to USB / Parallel Cable connected printers.
This is a brief explanation of why a network printer might not be printing; this is not a simple explanation. There are many variables, this is the most common.
This is one of the most common mistakes with Network printers.
A Network printer should bet set to a Static IP address (or fixed address)
Terms:
Dynamic Host Configuration Protocol (DHCP)
The Dynamic Host Configuration Protocol (DHCP) automates the assignment of IP addresses, subnet masks, default gateway, and other IP parameters.
Static IP addresses
When a computer / printer is configured to use the same IP address each time it powers up, this is known as a Static IP address.
Regardless if you printer is Wireless, or connected with a LAN cable to the Network.
The PC has a specific fixed location / address to find your printer; this was assigned when the printer was installed
(This can be found in the print driver under ports tab, something similar to 192.168.x.xxx, this is the IP address of the printer when it was installed)
If your printer is set to use DHCP, it will reassign a new address every time you reboot, shut down or there is a power loss.
(You might get lucky and it assigns the same address as previously assigned)
The PC will look to the address it was assigned at the time of the install and not the new reassigned address.
This assigned port in your printer driver is not capable of searching and updating the IP address of the Printer. This is not a Plug and Play item; it is not directly attached to the PC through Parallel Cable or USB.
If you reinstalled the printer after your system rebooted, you probably have the printer installed more than once. One works the other doesn’t! One has the correct address; the one that doesn’t work has the incorrect address.
If you do not set the printer to a static IP address this probably will happen again when it is restarted or there is a loss of power.
How to Fix this Problem:
1. Assign the printer with a Static IP address.
Read the manual specific to your machine, sometimes this can be found in the Set up Guide, or Administrators guide.
This setting can usually be found in the network settings of the printer.
You will also want to set the subnet mask, and the default gateway.
Which can be found using a PC? Click start, Run, type in CMD, and new black window will pop up, type ipconfig/all press enter, this will show all the network information you will need for this.
2. Making your PC communicate with Printer:
There are a few ways to do this, the easiest is to delete the old driver / printer and reinstall the driver. Most manufactures provide an automated click next type of install software. (Search their website for this)
You can also go into the printer ports of the driver and create a new port using standard TCP/IP port, and reassign to the new port.
This link is a to finding your print driver / print folder using a PC.
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
A patch cable directly from your PC to Your printer will not work; it will work with a crossover cable and a few minor changes to the TCP/IP settings. (You might get lucky using DCHP on the PC Side)
There are several ways to Network a printer.
Printer connected to Router etc…
The other way is P2P, or a shared printer
The Printer is shared from a PC / Server, which the printer can be connected directly to the Sharing PC via Parallel Cable, USB, or Networked through a router as discussed above.
In this Shared connection an administrator has control over the printing abilities of others that are using the printer.
The down side to this type of connection: if that PC / Sever is not powered on, having printer connection problems, or not connected to the network. Any PC which is using this shared connection will not be able to print.
I hope this helps, if you need any further assistance, let me know.
on Oct 26, 2008 | Sharp AR-164 Copier
How can I add a brother 145 printer so all laptops in the house can use it wireless
This model printer has only an USB printer connection and normally connected to a computer or laptop.
To connect this printer wirelessly to all laptops on your wireless network there are a couple of methods.
Connect the printer to a desktop computer and setup the printer as a shared printer. Next connect the desktop computer to your wireless router with a LAN cable and then configure the wireless laptops to connect to the shared printer on the desktop computer. NOTE - This desktop computer and printer must be on at all times for the wireless laptops to print to the printer.
OTHER METHOD
Connect the printer to an USB print server and connect the print server to the wireless router with a LAN cable. The printer drivers needs to be installed on all the wireless laptops and then the printer port needs to be deleted from the USB port and a new IP address printer port installed. This IP address will be the IP address of the print server.
Jun 09, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
"how to print settings for
If you are talking about one of the TallyCom print servers there is a small blue test button on the side of the box, press this when the print server is connected to a printer that is online. If you press the test button for over 9 seconds the print server will be reset to factory settings. If you want to print from DOS to a network printer as I recall you have two options; 1) Install the printer in Windows and share it, you can then print to the share name 2) Use "NET USE" command in DOS to map a local port to a network port, this is nessesaey if you can not print to LPT1 or COM1 from the application. For help of NET USE go to DOS and use the help options.
Jan 05, 2011 | Tally (43555) Print Server
Can the HP PSC 2410 printer be shared between 2 computers?
generally the printers with single USB port are dedicated for use with one computer.
However, depending on the way you connect the computers you can share the printer with more than one computer.
1. SET THE SECOND COMPUTER UP AS A NETWORK PRINTER
This is one of the most common ways to connect two home computers to the same printer. The advantage of this technique is that it doesn't cost you anything extra. You do require some computer literacy in networking though.
Firstly you physically connect the first computer to the printer via the provided cables. The second computer now needs to be set up as a network printer to have printing capabilities. The computer not physically hooked up sends a message via the network to the computer which is physically connected to print.
To set up the network connection in Windows follow these steps:
-Open the control panel
-Select the network or network and sharing icon
-You should see an icon named file and print sharing or simply print sharing. Turn on printer sharing if it is off.
(This requires your two computers to already share a network connection; otherwise you will have to set this up).
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/print_sharingw.mspx?mfr=true
2. PURCHASE A PRINTER SWITCH
A simple old fashioned way to connect two computers to one printer is by hooking them up to one switchbox in the middle. This switch is what is connected to the printer. This is a similar method to using a router to distribute the Internet to more then one computer.
This method is good for people who aren't very computer literate when it comes to networking. All you have to do is plug the cables in and off you go. However, it has one large disadvantage which is that the computers and printer all have to be in close proximity for the cables to reach.
The printer server should support the printer so that you can get maximum functionality from the printer device (including the multifunction feature).
http://cgi.ebay.com.au/Gray-Steel-Two-Ports-Printer-Sharing-USB-Switch-Box-/180502082365?cmd=ViewItem&pt=AU_Computers_Printer_Accessories&hash=item2a06c3333d
3. You can buy a printer server but for that you need to make sure the device fully supports the printer you have got including the multifunction features. Both computers will need to have network connection.
Something like http://www.netgear.com.au/au/Product/Print-Servers/Wired-Print-Servers/PS121
or
http://www.belkin.com/IWCatProductPage.process?Product_Id=354892
May 07, 2010 | HP PSC 2410 All-In-One InkJet Printer
Can i hook my printer to this router Linksys wireless-g 2.4ghz
You want to connect a printer to the network.
If you have Ethernet port on the printer then you can connect it to the router with the ethernet cable. IF it is wireless printer then you will need to connect to the wireless network on the printer. In both the cases you will need to set up your printer as a network printer. If you contact the manufacturer of the printer they will tell you how to do it.
If you do not have ethernet port on the printer and it has only USB port and it is not a wireless printer then you will need a print server. You can purchase a wireless print server and you can set it up so that all the computers will be able to print onthe same printer.
If you have only the USB port and you don't want to use print server, then you can connect your printer to one of your computer. Enable File and printer sharing on all the computer. If you go to microsoft.com and search for file and printer sharing, you will get steps to enable file and printer sharing.
If you want to check the wireless settings of the router, you will need to open the set up page of the router .
Click here for more information about router and networks
Mar 21, 2010 | Linksys Wireless-G WRT54G Router
Can I connect my printer to the uverse router USB port for sharin
If your using Windows operating system you can share your printer. That way you can keep your printer on one pc and when the other pc wants to print it will connect to your printer over your home network and print.
How to setup it in Windows XP
To share the printer, I opened the Printers and Faxes folder on the computer that was connected to my printer.
To open the Printers and Faxes folder
• Click Start and then click Control Panel.
• Click Printers and Other Hardware, and then click Printers and Faxes.
• In the Printers and Faxes folder, I clicked the printer's icon and, in the tasks pane, I clicked Share This Printer.
• I opened the printer's Properties dialog box, and clicked on the Sharing tab.
• I clicked Share Name, and then clicked OK.
That's it—the printer was immediately available for other computers to use.
Now that I had a network printer, I was ready to connect to it and print from other computers on the network.
To connect to the printer
• I opened Control Panel, and clicked Printers and Other Hardware.
• I clicked Add a Printer.
• Instead of adding a local printer, though, I clicked Printer Connection and then browsed the network for the printer.
The whole process took less than a minute before I was printing to the network printer as though it was connected to the computer.
Nov 30, 2009 | Computers & Internet
Level One Print Server not serving
Hi Mr Giles,
If you click on your Network icon in the bottom right hand corner of your Vista Desktop, and click Network and Sharing Center, is Printer sharing enabled?
Chris (ziraffa)
Jan 18, 2009 | Levelone ServCon WPS-9122 (WPS9122) Print...
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Connecting printer to SBS (Small Business Server)
You can physically connect the printers to the server and share it from there or leave the printers connected to your computer and have the server connect to them via a Local Port which routes to your computer!! To do the Create the local ports you'll need to 1.) share the printers on your pc 2.) Go to the server and go to printers in control panel 3.)Click on Add a new printer then next 4.)Select Local Printer connected to this computer; De-select Automatically Detect Printer 5.)Select Create new port and select Local Port 6.)In the enter a port name, enter the full network path to the printer i.e. \\your-pc-name\printer-share-name click ok 7.) Select the drivers for that specific printer(if its not there click on have disk then browse to the drivers to install them) 8.) Continue through the installation until finish) 9.) Repeat steps for additional printers Keep in mind that your computer still needs to be on! You can check to see if your printer support a network card to make them fully network printer you can add them to the server this way and only the server would need to be on! Or you can also get a print server(Device that makes regular printers into network printers). Now when it comes to the scanning, i don't know of any way to share a scanner with just windows alone, but there are third party software that allows you to do that Check out http://www.remote-scan.com/ There are also printers that sorta do the scanners sharing by automatically scanning and putting files in a designated area on the network! Hope this was helpful regards, babb
May 02, 2007 | Canon LaserBase MF5650 All-In-One Printer
Acer Aspire™ T180 PC Desktop Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
