Question about Iomega Computers & Internet
I have an omega RDHD-U 1 terabyte drive, I plugged in the wrong adapter, and now the light just flickers, and does not start, can I replace the hard drive controller(if that is what its called) or are there any other options.
    Scholar:
  • 118 Answers
If you have overcharged the harddrive, you have probably burned it and you need to go to a harddrive recovery specialist to recover any information you really want from there.
or, you might have only fried the circuits and then you need to go to a hardward technician to repair the circuits around the harddrive.
either way, it requires physical work.
Posted on Apr 06, 2011
External hard drive won't start up
assuming that "wont start up" means that the drive letter is not visible thru windows explorer/my computer, which is already installed and booted from an internal hard drive...
the seagate drives, often, require a patch to work with some windows installs- especially if it is larger than 3 terabytes, and occasionally, if larger than 1 terabyte. if this is the case, the patch is most easily obtained by emailing customer service.
if this is not the case, please provide more specifics as to your computer, your version of windows, and exactly what it is not doing when you say 'not starting"
Dec 24, 2014 | Seagate FreeAgent Computers & Internet
Iomega rdhd c2
to repartition you will lose all information on hard drive.
copy to another hard drive format to repartition then, then reload data back on.
Feb 22, 2014 | Computers & Internet
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
Transformer for Maxtor 1000GB has been lost. What are the specs for a replacement?
Maxtor One Touch 4 plus 1 terabyte external hard drive would need a 12 volt 2 amp power adapter with a positive inside tip.
That is if yours is the same model.
Oct 31, 2013 | Computers & Internet
I have an elements hard drive MDL:WD5000C035. When plugged in the green light on connecter will flicker once and then not at all and the blue light on the hard drive will not come on at all.
Typically, faulty adapters that have a green led or light when having no drive connected, stay on when powered. Once connected to the drive, the power led on the adapter turns off.
Sometimes the adapter can be replaced under warranty.
Select Warranty Check on the site for End User Costumers:
http://support.wdc.com/warranty/index_end.asp?lang=en
Select your country and enter the Serial Number, sometimes near the barcode ( not the model number you mentioned ).
When the adapter is still under warranty you do NOT have to fill in a sheet for an RMA ( Product Replacement form) for the hard drive.
You can make a phone call using the number that is free from charges. Look on this page for your country for phone support:
http://support.wdc.com/contact/index.asp?lang=en
When the adapter is out of warranty, you can look for a replacement in the WD shop. See next site:
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1378&p_created=1118358612&p_sid=1VgzXjvj&p_accessibility=0&p_redirect=&p_lva=1378&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9MCZwX2NhdHM9MCZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9MTM3OA!!&p_li=&p_topview=1
Mar 23, 2010 | Western Digital Elements powered by WD 320...
My Maxtor 3200
what was the voltage difference between the supplied adaptor and the one you plugged in by mistake ?
Robert
Dec 17, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
I think that this disk has some bade sector ,try to make a complete scan of tis hard drive by this command "CHKDSK /p /r" to repair this bad sectors and repartitioning this hard drive. some time the reason of this problem is file system of this hard drive is not correct.
Jun 14, 2007 | LaCie Bigger Disk Extreme (300789) 2000 GB
Computers & Internet Logo
160 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
