Question about Canon Office Equipment & Supplies
I am having canon ir6570. i have problem E824-001
    New Friend:
  • 140 Answers
It is related to primary charging cooling fan.
you canon check the connection of the connector on DC controller board socket NO. J103
otherwise you have to replace cooling fan.
Posted on Apr 06, 2011
I WANT TO INSTAL IN MY PC 64BIT DRIVER OF CANON IR6570 MACHINE
You can download the driver for your Canon IR6570 through the link below :
http://tinyurl.com/5v734xz
Choose your operating system then start the download process. You will encounter a "capcha" prompt so ensure to input the correct code. Example :
Thank you for using Fixya.
Feb 20, 2011 | Computers & Internet
Sir ; i have a canon ir6570 machine,it was
this problem due to an over current has been detected in the toner feed motor,you must check the connector or replace the motor
Jul 30, 2010 | Canon IMAGERUNNER 6570 Copier
I have canon ir6570.its shows e001-001,e001-0010 repeatly
try to clesr the err. from service mode ( * 2,8 * ) function - clear- err- press ok
if not ok
you have a problem in the fixing unit
Apr 01, 2010 | Canon IMAGERUNNER 6570 Copier
We have an f105 error what can we do?
Hi...
I Have Canon Ir5570 but i want up speed to Canon Ir6570.
I want Binary file for FRAM COUNTER Board In Chip IC #MB85R256 form Canon Ir6570.
And I want Binary file for Serial Board In Chip IC #BR93LC46F-W form Canon Ir 6570.
Dec 29, 2009 | Toshiba e-Studio 350 Copier
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
Canon iR6570 waste toner
look on the right rear of the machine, there should be a door with 2-4 screws. A big white plastic container should be there, remove dump toner and seal bag, replace. Make sure it is sitting properly, it uses a weight system.
Sep 08, 2008 | Canon IMAGERUNNER 6570 Copier
337 people viewed this question
old marine
old marine
