SOURCE: how to make a wi-fi connection to my sylvania net
first you have to be in a wire less hot spot starbucks library etc then you click the wifi icon on desktop then click it to power off (trust me i own one)you will see a wifi icon appear in task bar if it has no red bars next to the icon your on if it does double click the wireless icon in task bar and click wireless connections and click on the ones that are available to you if they ask for a network password you will need it ask who you are trying to connect to (also go to digi gadgets.com they have a free download update for the wireless system good luck
SOURCE: I recently bought a Sylvania 7 inch netbook sold
Your OS should have an icon on the desk top that says WIFI Power, it is blue in color and this icon turns the WIFI on and off. When the button says off, the WiFi is on, the idea is that it is waiting for you to turn it off. If that is not on your desk top, turn the machine over and look for a small hole 1in diagonally right of the data plate. insert a tooth pick in that hole a depress gently to reset your machine. It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
On the left side of the main screen, you will see an icon that says "WI-FI Power". That's the switch to turn it on. When you click it, a little box will appear that says "turn on" when it's off and "turn off" when it's on.
But you have to do more than that. Next, I suggest to Google "digitalgadgets.com". Find "Sylvania products", click on "7 inch netbook support" and follow directions.
For # 4 you will find your "hot spot" name". Click connect.
For # 5 you may have to call your "Internet Service Provider" (Charter, AT&T or whoever you pay for your internet-to get your "network keys", etc. Then click ok.
Next be sure you go to Start, Settings, Control Panel, Internet Options, General and then complete "User Agent (requires Browser Restart)" by selecting:
"Default" (same as Windows XP)" or
"Same As Pocket PC" or
"Windows CE"
I selected "Default" and was off and running.
-dka-
SOURCE: My sylvania netbook wont connect
To
connect to your wireless router, it needs the router's wireless settings
configured and also the wireless cards in all the laptops and or
computers needs to be configured with the router's wireless settings. Then the
laptops and desktop computers can communicate with your wireless
router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: Wi-Fi connection problems with a Sylvania netbook.
Please try and follow the detail below. It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver. sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing Additional Information When I try to sign on with the red X showing, I get "The page cannot be displayed If I then double click on the icon down in the right corner I elucidated above, RT28701 opens up to "Internet Protocol (TCP/IP) with all zeros in the IP address field, and Subnet Mask, with no entries in the default gateway. That is a clue to me that the auto sign on has not found a viable network or needs something else. If I then click on Wireless Information tab, The list of available networks appear in the box. The machine keeps trying to associate my previous entered name site with my prefered site and tells me the signal is good, but it cannot link up. This is a signal to me that it has lost my Network Key or that the software has failed or both. I then click on advance and delete my prefered network and hit OK, this will force the software to ask me for my network again, and notice that the prefered is missing. I click on the name of my network again and then hit connect., then the Wireless Network properties window opens up and I can insert my Network Key again after I uncheck the "The key is provided automatically" box. I enter the key and hit the OK button. I still do not get a connection, so I reboot the machine, and wait for about 30 seconds and the machine synchs up because the little RED X under the icon has disappeared. Now the machine will hook to the internet as long as I want to, but sometimes when I turn the machine on it will not synch, so I go through the above sequence again. The secret is once you have entered your key and ask for the machine to synch up you have to reboot. Why? I do not exactly know, but I suspect that the WiFi driver looses it You may also want to look at TIP at: http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard http://www.fixya.com/support/r7957741-sylvania_synet07526_owners
