Question about Toshiba Cameras
Where can i find toshiba charger for digicam camileo s10?
  • 90 Answers
Sir go to a near by servicing center.They will provide you the charger.
Posted on Apr 06, 2011
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Toshiba camileo s10 wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 11, 2012 | Sony Ericsson Hazel J20i GreenHeart...
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
I need to get an Instruction manual for Toshiba A35 Camileo video camera and also a charger unit wher can I get them.
Have you tried putting the info in your browser or go directly to Toshiba.com and ask for manual and charger unit for this particular model.
Apr 02, 2012 | Toshiba Computers & Internet
Camileo s30 not charging
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Mar 15, 2012 | Toshiba Camileo S30 HD Camcorder -...
Camilio s10 wont clear card locked
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Jan 22, 2011 | Toshiba Camileo X100 High Definition...
Charging continues to flash even after 3 hours of charging Toshiba camileo h30? Booklet said it should stop flashing when charged, but hasn't. Thanks in advance Paul
have you checked that the charger is charging the camera battery up?????
it could also be a dud camera battery,,if one cell is duff the hole battery wont charge up to its full volts so the charger works its **** off trying to charge up a dud battery till one day the charger just burns out as well?
Nov 27, 2010 | Toshiba Camileo H30 Hard Drive Camcorder
Cameras Logo
81 people viewed this question
Top Toshiba Cameras Experts
john milligan
isaac johny
isaac johny
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
