Question about Brother HL 2140 Laser Printer
There is a line of ink spots that runs the length of the paper (almost looks like a fancy spotted margin).
  • 2,510 Answers
Locate and check the printer drum. You should be able to see the mark that is causing the line on your page. It could be s scratch or a ring of toner that the wiper is not picking up because a nick or something under it. Try cleaning the drum with a very soft dry cloth and inspect it again. If the mark is still there the drum will have to be replaced. Do Not Try To Clean The Drum With Any Type Of Solvent!
Posted on Apr 06, 2011
I always have a black line down the middle of the page when i scan. help
If there's a black line when scanning but not when printing, you need to clean the scan bed. Either the glass has something on it or check the paper path if you're using the ADF. A single ink spot either place will print a line down the whole length of your scan.
May 12, 2011 | HP Officejet 6500 Wireless All-in-One...
Copies paper great except leaves a long invisible 1 inch thick line down the middle
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
Feb 13, 2008 | Canon PC1061 Copier
Screen has white line that runs length of screen also has dark spots at bottom that looks like ink .
The white line is problem of the LCD's electronic. The spots are places where the liquid crystal is out of order of it's molecules, result of a shock and/or crack. Both problems cannot be fixed and the LCD screen have to be replaced. Take apart the lid and look the partnumber of the LCD on its back. Find replacement on ebay.
Aug 25, 2010 | Gateway NV5213u (LX.WDM0X.001) PC Notebook
Changed colour cartridges but it still says drum error
The "drum" is where the laser adds/subtracts an electrical charge to each spot on the drum.
The printer "throws" the powdered-ink at the drum.
The ink sticks to the "charged" spots, and does not stick to the "non-charged" spots.
Then, the printer puts a sheet of paper in contact with the drum, and the ink is transferred to the paper.
Then, the "fuser" heats the paper & ink, and "melts" the ink into the paper.
So, changing the ink-cartridges will _NOT_ fix any "drum" problem.
Jun 01, 2010 | Brother MFC-9440CN Laser Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Ink spots on paper
If the spots are all one color, the toner cartridge of that color has a problem. Check the drum on that cartridge and make sure there are no bad spots on it. Your cartridge could be leaking toner.
Feb 27, 2009 | HP LaserJet 4600dn Color Printer
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Getting spots on photos
I pulled out the cartridge that was causing the spots, dabbed at the small pool of ink that collected with a very soft paper towel, re-cleaned the print heads and that seemed to solve it...
Jul 11, 2008 | Epson Stylus 1400 InkJet Photo Printer
Top feeder of AL-1655CS
that is a dirty glass. The 1 inch or less wide glass on the left side of the machine has a very small spec on it.
You can clean it with a regular piece of paper and alcohol. Don't be afraid to clean it with some decent pressure.
The reason why you get the line in the feeder and not off the glass is that when you run a copy off the glass the lamp scans the immage, when you run through the feeeder the lamp parks under the glass and the movement of the document makes the print.
You may have some white out, or just some ink off an original on that piece of glass, but keep that clean.
Most people don't think that small piece of glass has a purpose, but it does. Sometimes the blot on the glass is so small you cant see it, and you need to remove that glass and hold it up with a piece of paper behind it to see the spot. It can be a very very small spot. But that is where your issue is.
Mar 10, 2008 | Sharp AL-1655CS Laser Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
Brother HL 2140 Laser Printer Logo
117 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
