Question about Liebherr Refrigerators
How to replace the door seal of Liebherr KGTes 4066, Index 25C/001?
Replace seal on Liebherr french door
Are you talking about the center door gaskets? If so, Purchase new gaskets Left and Right (2 different part numbers) from Adco Service of Scottsdale AZ. The gaskets pull out from the two grooves and put liquid soap in the new gasket channel that holds the heater wire. Observe the channel where the wire came from.. Insert the heater wire slowly until it is at the end. Starting at the top, insert the gasket tongue that is towards the inside if the refrigerator first all the way down, then insert the side at the edge of the door. Be sure to firmly seat the gasket
Dec 23, 2013 | Liebherr CS2062 Bottom Freezer French Door...
The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
Oct 18, 2012 | Liebherr Refrigerators
Hi, we have had a liebherr KI 2444 intgrated fridge/freezer since new, 10 years ago and it has been very reliable. We have noticed an increasing build-up of water gatering on shelves and items, which is...
Most likely condensation caused by a faulty seal. I am in the UK, no idea where you are. Try looking up espares or another spares company in your country.
Apr 16, 2017 | Liebherr Refrigerators
Alarm is going off (beeping) - ice accumulating on rear freezer wall.
hi check the doors seals if it closed perfectly and do not open the fridge or freezer door for long time because if you forgot one of the doors open it will make this problem and do not put hot or warm food inside most important to be sure that the seals stuck good when you close the fridge doors.
Sep 11, 2010 | Liebherr Refrigerators
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
Alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Mar 01, 2010 | Liebherr Refrigerators
Ice keeps accumulating in back of fridge. We've tried cleaning drain but it doesn't seem to help.
If the drain is clean and there is sufficient space for air to flow around the food, the only thing left is to replace the door seal. It is allowing moisture to enter the freezer. The fan inside the freezer, actually burns the frost off of the food. If the seals are bad, it can never catch up.
Sep 17, 2009 | Liebherr Refrigerators
Our liebherr freezer door seal has broken, should this cause the fridge to warm up.....5 upto 17 degrees?
All sorts of things can go wrong. Warm air will be sucked in and typically there will be water dripping from the cieling. The compressor will also continue to run .Will almost certainly get an ice build up on evep. plate. Suggest replacement as soon as possible.
Sep 16, 2009 | Liebherr KTS 1534 Comfort Compact...
The freezer on my Liebherr fridge keeps filling too much with ice. The ice grows around the door and seal which makes it impossible to close properly. I inherited the f/freezer so I don't have the...
This sounds like moisture in being sucked in past the door seals. Remember, cold-- sucks temperature, (like a vacuum) and HEAT--- pumps away temperatures..So the warmer temp. are always being drawn in.. Thus, bad door seals, and need to be replaced --- cleanned---or repaired, but for now turn your thermostat or temperature up or the control knob back lower, (like from 7--to 5--ect. ect 4-to 2..)!
Sep 06, 2008 | Heating & Cooling
Refrigerators Logo
114 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
