How to reset n program eprom for motorola gp 2000 with RIB. and without open radio
5 Suggested Answers
icom andy
SOURCE: please Help me
MOTOROLA GP-2000 Programming Instructions
Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration
From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If the radio is turned on, turn it off. Press and hold the MON button and turn the radio on. A ringing tone will be heard,which indicates that the radio is in Programming mode. The PW and [] indicators are displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
Posted on Nov 20, 2007
SOURCE: HOW TO OPEN FREQ
you need to have the radio programed with motorolas rss program.
Posted on Oct 14, 2008
  • 14 Answers
SOURCE: motorola gp 63
The GP-63 and the GP-68 uses the same users manual. You can download the user manual which also has programming and cloning information in it from:
http://www.batlabs.com/2way.html and choose GP-63......Good luck
Posted on Oct 30, 2008
Neto
  • 123 Answers
SOURCE: Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Posted on Feb 04, 2010
Testimonial: "Thanks for the response. appreciated it. It is very useful."
I have purchased a second hand set of Motorola xtnid radios, the old company's name is still displayed in the screen when I first switch it on, how do I remove it ?
Depending on the radio, mots Motorola business radios are programmed with a computer and a cable that attaches the radio to the computer, or a programming RIB. This all depends on the age and model of the radio, but since you said that a companies name appears in the display, I am pretty sure it is a business band radio that has to be professionally programmed. I say professionally because even if you have everything you needed to program the radio, I sincerely doubt that you will be able to do it. Motorola software is called CPS, but then again, it depends on the age of the radio, newer Mototurbo XPR radios use a much newer software, and they interface to the computer in a different way, that is without the use of a programming RIB. A RIB is a box that goes between the radio and the computer, newer radios only need a simple USB cable that is made to mate the radio to a uSB port.
Dec 09, 2015 | Radio Communications
How to reset the program
The battery eliminator does not require programming. (This is the category the question was posted in.)
If you are referring to the radio, you will need to visit a Motorola dealer for programming. It requires software, cable and a RIB (radio interface box). The software is proprietary to Motorola and available by subscription to dealers and qualifying entities.
Best regards.
Apr 16, 2013 | Motorola GP300 Compatible 2 Way Radio...
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
How do i program my motorola mts 2000 flashport scanner
Your Motorola MTS2000 is not a scanner but a high-end two-way radio. It requires a computer, special interface box (called a RIB, for Radio Interface Box), the proper cable from the radio to the RIB, and the programming software called RSS (Radio Service Software.)
This is much more difficult than a scanner to program and if not done properly can cause the radio to automatically transmit on frequencies that you are not authorized to use.
Try calling your local Motorola dealer and ask them if they will program it for you for receiving only. They will either flatly refuse or they will be happy to charge you a service fee. Some places are more willing than others.
Dec 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
May 01, 2009 | Radio Communications
Motorola gp-68 low battery beeps comes on too soon
I'm not sure that you can manually reset the low voltage threshold on your radio. Most of Motorola radio use programming software to turn on/off low battery beep and many other features. Everything is done by software.
radcom907
Mar 10, 2009 | Radio Communications
How To Channge Frequency s in Motorola GP300
MOT GP 300 need RIB box and the software for the programming.
Give a google search for the home brewing of the RIB box.
Software is licensed and have to seek the support of a MOT dealer/ service.
Feb 25, 2009 | Motorola GP300 Compatible 2 Way Radio...
HOW TO OPEN FREQ
Oct 12, 2008 | Radio Communications
Please Help me
- Turn off radio
From Dealer to User
- Turn off radio
RW = Radio Wide
Nov 06, 2007 | Radio Communications
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
