Question about Hoover Washing Machines
Hi there, I have a Hoover Front Loader Electra-economiser 550 dual spin - and i think it just might be blocked as once the load is done, there is still alot of water that hasnt drained. How do I go about unblocking it?
  • 641 Answers
SOURCE: Washer won't fast spin or drain
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Posted on Sep 04, 2007
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
  • 1294 Answers
SOURCE: Hoover Electra 540 Dual Spin.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
You can give them the diametre (inner/outer), length, you can of course get it, substitutes, at your local shop also.
Posted on Mar 21, 2009
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
Posted on May 04, 2009
Door does not unlock after spin cycle on hoover electra 530 dual spin washing machine
the door interlock is aok i think the vacuum switch hoze is blocked up with grub
clean the whole hozes inside with pipe cleaners
i get them from the local home brew shop and ebay pipe cleaners
and use a calgon tablets or bleach mixed with soap for a full washing soap too clean all the pipes
and esp the pump!!! and clean it out
take it out brake in half pull out the viens and clean with like the green jaggy rought cloths ...
youll find the pump vien unit comes free of the bearings .
reasemble
or if your not confident to do it
show this post too the tech you employ
and tell him this is a ~£40 max job
Mar 05, 2015 | Hoover Washing Machines
Electra 535 Dual Spin - I`m trying to discover what the capacity of this machine is, the manual supplied with the machine gives all spec.s apart from its size. ie is it 6, 6.5 or 7. kilos...
From what I remember, the 535 is a 5.5 kg machine. The best way to load any front loader is to have the tub full but not packed. Its the safest. As for weight capacity, due to Australian Standards testing, machines have to state what load they will handle with a certain volume of water and power usage, but any front loader, load it up but dont pack the clothes in and you will have the best efficiency. By the way, the clothes are measured dry weight..
Jul 31, 2011 | Hoover Washing Machines
My Hoover Front loader is leaking water from underneath the machine. It is NOT the taps..I believe it could be the rubber seal just inside the door of the machine, as it has a hole in it. Could this be the...
If the hole goes right through the seal it could be the cause, but I am inclined to think it is a vent hole for the seal and that a leaking seal will come out on the front panel. Remove the machine back and check the pump seals and the hoses, it is more likely those at that age. Take care, there may be live terminals and connectors inside the back of the machine when the power is on.
Mar 27, 2011 | Hoover Washing Machines
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Oct 19, 2009 | Hoover HTC243 Top Load Washer
Hoover Electra 540 Dual Spin. Are hoses still available for this model? I require the hose from the filler to the drum and also from the drum to the pump.
Sites for spares:
RepairClinic.com
espares.co.uk
Mar 06, 2009 | Hoover AAA160 Front Load Washer
Drum not turning
Problem sorted, motor is brushless and tested ok. Traced problem to statup capacitor, no circuit across terminals, will be relatively cheap fix
Jan 21, 2009 | Hoover AAA160 Front Load Washer
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
