Question about Electrolux 23 in. ESL6114 Built-in Dishwasher
Have ESL6115 Electrolux Dishwasher (Built in). About three quarters thro wash, it trips the RDS circuits. When plugged back in, and switched on, it finishes wash with no further problems. WHY??
I have the same problem. The water riser pipe at the back right corner of the machine leaks where the pipe goes through the stainless steel wall of the machine at the top, you can see the end of the pipe from inside the machine as a grey threaded plastic nut. The water runs down the back and collects in the bottom. This only happens when the water is being pumped into the machine to circulate through the washer as the water is under pressure.
The breaker will trip when a leakage to earth or a short circuit is detected caused by the water, my machine has actually been flashing over in one place by the short curcuit caused from the water, the flash over vapourises the water so that when the breaker is reset the machine runs for a while longer before doing the same thing.
The pipe and/or seal needs to be replaced to stop the leak and then it should be ok again. However if water ingress has been a problem for some time other components may be affected. Best have it checked by a pro if this is the case.
Posted on Jun 08, 2011
My dishlex dishwasher tripped the fuse what could be wrong
reset the circuit and try again.but it sounds like you got a short.
Jan 03, 2015 | Washing Machines
Dishwasher trips mains
Good Morning Friend,
I understand that your Electrolux dishwasher, model# ESL4114, keeps tripping your main breaker. This appears to be a UK Electrolux dishwasher. I suggest contacting the manufacturer directly for further assistance. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
Electrolux EWDW6505GS error 01
Good Afternoon Friend,
I see that your Electrolux dishwasher, model# EWDW6505GS, is having trouble with an error 01. I suggest resetting your dishwasher. You will do this by either unplugging it or shutting the power off at your homes circuit breaker for 20-30 minutes. When the power is restored, run a wash. If your dishwasher is still experiencing an error 01, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 20, 2014 | Electrolux EWDW6505GS Fully Integrated...
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
The fuse keep on blowing after few minute of use in electrolux dishwasher ESl4114
Hi, the most common fault on a washing machine is when the heating element is breaking down it will cause a trip or a fuse to go because it is a "resistive load" i.e a small short circuit.
Try to put your washer through a cold wash cycle if it completes the cycle without blowing the fuse then you know that you need a new element. If it still blows the fuse then you are looking at most likely a motor problem.
Jun 11, 2011 | Electrolux 18 in. ESL4114 Slim-Line...
I have an Electrolux ESL6115 dishwasher model and although there is water coming out and the spray blades seem to be turning the dishes are always wet after the cycle has finished and there appears to be...
Its possible that if you live in a hard water area that limescale buildup is causing this problem if salt levels got low. The first thing that can be done is to run it with 2 or 3 cups of vinegar added & see if it cures it. If it won't accept opening the door to add this after wash has started then add it in a wide dish to catch water & wash it out during cycle. Adding a dose (half cup) of bicarbonate of soda alongside should work even better. This has worked really well for washing machine about to give up on & do regularly to prevent problem. Hope this helps.
Apr 28, 2011 | Electrolux 23 in. ESL6114 Built-in...
My dishwasher electrolux esl6115 is leaking from the bottom of the door during the cycle.
My dishwasher electrolux built in unit was leaking, turned out to be the plastic nut inside on right hand side where water feeds the top rotar was loose. I actually took side off and found it running down inside and flooding out the feet and sides. Solution in my case was to wrap PTFE around the threaded section and rescrew nuton tightly..Problem solved. Simples.
Nov 15, 2010 | Electrolux EDW5505ESS Built-in Dishwasher
Dishwasher will not start
Go to your electrical panel and turn off the circuit that feeds your dishwasher. It will also turn off the clean light. Wait three minutes and then turn the circuit back on. That should reset your machine.
Apr 07, 2009 | Electrolux Frigidaire Professional Series...
Electrolux 23 in. ESL6114 Built-in Dishwasher Logo
418 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
