My dell keyboard is not working some times? this is usb keyboard
  • 34 Answers
Try these keyboard on a different computer. If its doing the same thing, the problem is already the keyboard.
Posted on Apr 06, 2011
Forgot password dell optiplex gx270 how do I bypass the password
If a keyboard fails it is due to damage to the contacts or connection, and many times it is from abuse, water or other fluids entering the board spaces, or burnout. Replacement is easy, and boards are not expensive. If you do not wish to replace the Keyboard, use a USB standard keyboard used on any computer. Simply plug a USB Keyboard into any USB port of the Desktop or Portable. Done!
May 01, 2014 | Dell Optiplex GX 270 Desktop Computer...
Disable inspiron 1525 keyboard
Step 1:
Dell sells technology such as computers, computer peripherals and consumer electronics to both consumers and businesses. Dell sells both wired and wireless keyboards and mice that are compatible with Dell and other computer systems. Dell wireless keyboards may encounter hardware, software or other problems under certain conditions.
Power Dell wireless keyboards transmit data to the Dell USB receiver, which in turn passes the data to the computer's operating system. The keyboard gets power from two AA batteries. As the batteries lose charge, the keyboard's transmissions can become intermittent. Replacing the old batteries with fresh ones will ensure consistent communication and resolve the power issue. b> Interference Dell wireless keyboards operate best and are least susceptible to interference when the user places them at the recommended distance from the USB receiver. The distance, specified in the keyboard's accompanying software or installation guide, varies by keyboard. Even if the user places the keyboard at the proper distance from the USB hub, metal objects between the keyboard and hub can create interference; moving objects that create the interference resolves the issue. b> Connection The Dell USB receiver that passes data from the keyboard to the computer requires proper and secure installation in a working USB port. If the receiver connects to the USB port improperly, or if the USB port to which the receiver is connected is faulty, the keyboard will not operate as expected. The user can reseat the receiver in the USB port, or connect to the receiver to a different, functioning USB port to resolve connection problems. b> Synchronization Dell wireless keyboards can broadcast at more than one frequency, just as their associated USB receivers do. If the two devices broadcast at different frequencies, they will not pass information to each other. The user can resolve this situation using the buttons labeled "Connect" on the top of the receiver and the bottom of the mouse. Pressing the buttons simultaneously triggers the synchronization process. b> System Dell wireless keyboards are compatible with most Dell systems. However, a keyboard may be incompatible with a given computer for reasons related to the computer rather than to the keyboard. To determine if this is the case, a user can connect the keyboard to a different computer. If the keyboard functions as expected with the second computer, the problem may reside in the first computer rather than in the keyboard.
Dell wireless keyboard problems
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=715E6659A4141AFAE040AE0AB7E10D59&doclang=en&cs= - Issue0_1
Feb 20, 2013 | Dell Inspiron 1525 Notebook
Dell optiplex gx520 keyboard
its not the on your USB connection, your keyboard is malfunction... buy a new one or keyboard
Jun 17, 2009 | Dell OptiPlex GX520 PC Desktop
Dell SK-8115 USB Keyboard on none Dell PC Issues
Have you gone in and removed the usb drivers by doing the following.
1.) right click on my computer
2.) select properties
3.) Select Hardware tab
4.)Select device manager
Then remove all instances of usb that you can.
You may have to try this using just the mouse for navigation. Right click on usb item then select uninstall. Remove all the ones you can then reboot the computer. You may have to reboot a couple times
Then try the keyboard it should work no problem
Jan 16, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Dell SK-8115 USB keyboard on non Dell PC
This model keyboard has an internal USB hub and Windows only sees the hub when booting. The solution is to get a generic USB keyboard and boot into Windows. Once Windows has loaded the HID drivers for the sk-8115 keyboard then this Dell keyboard will work from then on.
On booting up, computer can not load keyboard system.
One possible problem is that your PS2 keyboard port at the back of your PC is ruined. In time, those so called "outlets" become loose specially the ones with cables which usually got pulled or tangled and make the port strained and the contacts get loose.
If that is the case, you might need to replace the keyboard port, or just stick with your usb keyboard.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Keyboard error
have you tried it in a different usb port. or are all the ports not working. Because Dell usb ports have drivers and if the drivers don't work then neither is your keyboard and mouse
Go here and use the 6th one down
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=usb+drivers+&cat=sup&x=14&y=9
Nov 22, 2008 | Dell OptiPlex GX520 PC Desktop
Dell keyboard SK-8115
(That is the the Num Lock indicator, nothing to worry about.) If it is not working it is likely because USB keyboards can time some time to be recognized by windows, let the computer boot up with the keyboard connected and let sit for up to ten minutes.
Sometimes if other hardware is detected at the same time which requires drivers to be installed, windows will never proceed to installing your keyboard, however you cannot install the other drivers until you have a working keyboard. To solve this, you will need to use an older style PS/2 keyboard to get everything installed and working as they do not need to be detected.
Nov 11, 2008 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Problem with a dell computer..
You may try connecting a different usb keyboard to your system. Mostly, some keyboard converted from serial connection to a usb could cause this kind of problem. In some cases also, wireless keyboard and mouse won't work when u turned on your system if the driver is not properly install.
You may also try disconnecting any other usb devices from your computer. Disconnect also your power supply then push and hold the power button for 5 seconds. Plug back in the power cord then connect your keyboard. Turn on your computer. if it doesn't work, i suggest to call your computer manufacturer and check your warranty. This could be an issue with the motherboard of your computer.
Keep me posted.
Thanks.
Jeff
Oct 12, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 3000 keyboard error
hai pls enable usb option in cmos and then press f10 and then press yes and then restart and see . or else reinstall the usb drivers
Sep 08, 2007 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
