Question about Sport & Outdoor - Others
I can not set altitude on my TCM Winter sport Watch
Go to altitude view (ALTI) - may need to press 'Sensor' (top left) once, and then 'Mode' (bottom left) to display.
Press and hold Mode until display starts flashing. Keep pressing Mode until the setting you want to change is flashing, then use right-hand side buttons to change.
Press and hold Mode again to get out of the setting interface.
The different altitude settings which you can change between using the Start/stop (top right) button:
ZERO - for use when skiing or when you want to measure a relative change in altitude.
ALTI - Input known measurement above sea level
SEAP. - Current air pressure
F.DEF - Factory reset barometer to 1013.2hPa
Posted on Jul 19, 2013
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Dec 15, 2015 | Watches
I calibrated my Timex WS4 using a known barometric pressure and set the weather conditions but the watch is telling me I'm at an altitude of -42 meters (which I'm not) and the temperature is at least 10...
You should carefully read the manual on this watch. It is a very sophisticated instrument realitive to its cost.
The barometric pressure in the CAL mode is set to the reference sea level. The pressure that is read in the other areas is the actual or relative pressure at your location.
There are some tollerences for the accuracy of these watches. What they are excellent at is seeing the relative differences or changes. I found that when I set the reference barometric pressure (Sea Level Pressure), everything falls in to place. I found the WP4 to be accurate to within about 15 to 20 feet accuracy for altitude most of the time. It is important to periodically check the barometric pressure from the weather office if you want it to be as accurate as possible.
When hiking or out trecking, it is advisable to check the watch's altitude relative to the map that you are using, or to a known reference. Then as you travel you can check for the altitude change.
Take care that this type of watch is to be used as a quick or easy reference only. It is not certified to be used in situations where life and safety are fully dependent on the readings from this type of watch. It is a precision instrument, but not as precise as the high end professional certified types. It is best to refer to proper maps (charts), and depend on a certified mechanical compass for absolute reference.
Jerry G.
Apr 04, 2011 | Timex Expedition WS4 WideScreen 4...
I have a black and dark grey digital watch marked TCM on the back with 4 buttons saying "bearing", "start/spl", "mode/select", "stp/light/set" around a circular digital face. On the back it says that it...
  1. Hold and press upper left. (backlight turns up and cipher (to adjust) start blinking)
  2. Switch between the positions by pressing bottom left
  3. Set the cypher you want by pressing bottom left
  4. Repeat step 2 and 3 each time you need
  5. Press upper left to end of adjusting
To use the compass - upper right. To callibrate and set the declination, please search it. I just post that answer to another TCM 217362 watch owner.
Oct 21, 2010 | Watches
Can not seem to set my altimeter on the ws4 timex i have tryed do this but it is giving me the wrong hight ? and know one in the shops can figger this out to????? what am i doing wrong iv tryed to folow...
Setting and Calibrating Your Altitude
1. Press MODE until CAL is shown.
2. Hold SET to begin the calibration.
3. Press START/SPLIT (+) until HOME ALTI is displayed (or choose WEATHER when calibrating weather).
4. Press MODE (NEXT) to begin the setting process.
5. Press START/SPLIT (+) or STOP/RESET (-) to increase or decrease setting values.
6. Set the value to your current elevation.
7. Press MODE (NEXT) to advance to the next setting option.
8. Press SET (DONE) to finish.
9. To complete calibration for the REFRENCE HOME altitude (or WEATHER setting), press and hold STOP/RESET until watch beeps.
Repeat this procedure for WEATHER, making sure to choose the proper weather condition on the WS4 that matches your current weather.
Once these two variables are calibrated, your WS4 will be ready to go, providing you with accurate altitude, pressure, and weather forecast information at your fingertips. Enjoy.
Jan 05, 2010 | Timex Watches
What is the function of the EH- gearbox switch on a 1994 BMW 525i series
The EH gearbox switch serves to communicate with the TCM (Trans Control Mod). In A mode, it tells the TCM to operate in the most economical shifting program. M mode is for manual shift. If you have a * instead of a M, it stands for winter mode. This mode causes the vehicle to start off in 2nd so that torque is reduced thus reducing wheel spin on slick surfaces. Of course, by shifting into 4 or 3 puts you into sport mode for a more spirited shift pattern.
Sep 12, 2009 | 2007 BMW 525xi Sedan
2002 trooper A/T 4WD will not move from start or stop.
One of two things has happened. Either you have lost first and second gear in your tranny (Winter drive starts you out in third gear) or your TCM (Transmission control module) is shot.
Check the TCM first, it's the lesser (cheaper) of the two evils.
Jun 29, 2009 | 2002 Isuzu Trooper
High Altitude Electric Heaters
I have never heard of altitude effecting the electric. Watts amps and volts are different than burning a gas, like propane. The high altitude has less oxygen thus requiring the combustion to be effected. If your wires are over heating when you use maximum wattage (amps) you need to install larger wire with the correct size breaker. Look up ohms law. Its a basic electrical formula and will help you get this right.
Dec 26, 2007 | Dayton Electric Heater
Incorrect altitude changes
Here is the link to the user manual for this watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf page 12 gives you all the contact details for lacrosse. I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty. I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important). ask them to check if the sensor is clogged, it happens sometimes. Hope this helps :)
Jun 18, 2006 | La Crosse K2-100 Wrist Watch
Sport & Outdoor - Others Logo
235 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
