Question about Acer Aspire 5315 Notebook
Have an acer aspire laptop5315 recently it will not start up when i press start switch runs for 5 seconds then stops.if i remove hard drive and re insert it starts. the date and time also reverts back to 2001 2.00am.it will sometimes start if i keep pressing start switch.once it starts laptop is ok works well.any ideas
    Scholar:
  • 93 Answers
Find where the the cmos battery is located and replace it
I hope this helps
Andrew A
Posted on Apr 07, 2011
Get in to bios acer aspire AST180-ED400A
First shut your computer off. Wait a few seconds (to allow the hard drive to stop spinning) and start the computer again.
Start repeatedly pressing F2 while the Acer logo is displaying. Press it once, wait a second, press, it again, wait another second, and repeat this while the Acer logo is displaying until you see the bios setup screen.
Feb 19, 2015 | Acer Computers & Internet
My Acer Aspire 5920 does not start up after pressing the power button, nothing on the screen at all. However the lights are flashing. Before this problem, the screen froze when I was using it. What's the...
Possibly a RAM issue or errors on the hard drive stopping the display driver from working properly. Remove power sources, remove RAM and hard drive. See if you get a display when the power adapter is reconnected. If you do, remove power source and fit RAM, (if not motherboard may be faulty). Repeat and if still working, remove power, fit Hard Drive and boot again.
Assuming your OS is Windows Based;
Reboot and use safe mode run CHKDSK/F and when finished check the drivers.
Feb 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
Computer stops after 3 seconds from start
try takeing the battery and power lead out and holding the power button pressed for about a minute then plug it back in ,if there no joy then theres no easy solution to your problem without testing parts inside ,if under warrenty return it for repair or replacement ,could possably be motherboard
Mar 11, 2010 | Acer Aspire 5315 Notebook
Acer Aspire 5100 will not boot
Two possible Solutions:
1) The Hard Drive has come unseated - Disconnect the Power and REMOVE all connections, Close the Screen & Turn your Laptop Upside Down and Remove the Battery, Locate the Hard Drive Access Panel and Remove the Screws from the Panel, Remove the Panel, Remove the Hard Drive. Carefully Replace the Hard Drive, Replace the Panel and Reconnect the Battery & Power Supply. See if the Computer will Start
2) The Operating System is Damaged OR the Hard Drive is Dead - You will need to slave Your Hard Dive into a Second Computer and Backup ALL you Personal Data OR RISK loosing it. If the Second Computer can NOT read the Drive, the Hard Drive is Dead (A Computer Repair Company may be Able to Help)
Once your Data is Safe, you can try to Repair the OS by Booting your Computer with the Drive in it. Begin pressing F12 or F10 at bootup (Once a Second). You will be presented with an Options Page for:
System Restore (FIX WINDOWS)
System Recovery (Wipes your Computer and Retores the Factory Software)
Hope this Helps!
Dec 22, 2009 | Acer Aspire5100 Notebook
To stop acer logo before starting windows xp
Well, Firstly this might be a extreme case but is to reformat your hard drive removing any manufactures partition, and reinstalling the Operating System, but what i would do first is the go to start---run---(type this command and hit enter)"msconfig" the system configuration window should pop up. Go to the boot tab and place check mark in the box which says "No GUI boot" you mat also change the timeout seconds there too. hit apply then OK and reboot your system.
hope this works for you. let met know.
Oct 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
My Acer 5920 Laptop is about a yr old. It is not switching on. The power light blinks for about 5 secoonds and then nothing happens. Please let me know if anybody has a solution to this.
Try removeing the battery, memory and Hard drive. Press and hold the power button for 30 seconds.
Re-install and reseat memory Harddrive and battery.
Try powering up the unit without the battery and any external devices.
Sep 11, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 3003LCI Laptop Fan starts but stops after 5 seconds
remove the memory then make a clean or replace a new memory
Jun 25, 2009 | Acer Aspire 3003LCi Notebook
Acer Aspire T180
check your removable media disk drives and make sure that you don't have like a jump drive or CD-Rom that the computer doesn't like. If that doesn't work, enter the BIOS setup (usually F2, F12, ESC or something like that....check the bottom of the screen.) and find the Boot Order settings & move hard drive to #1
Jan 08, 2009 | Acer Aspire™ T180 PC Desktop
My ACer T180 does not boot boot up
sound like the hard drive. do you hear the drive spinning?? you may need replace or reformat.
what OS are you running....?
Sep 10, 2008 | Acer Aspire™ T180 PC Desktop
Blank screen
hard drive problems try to restart the computer and press the F8 key in the first 5 seconds this will display the page with some options choose last good know config or save mode if last know good config does not fix it try save mode if you can acces the hard drive you may have re install windows if no acces get new hard drive
Jan 01, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5315 Notebook Logo
158 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
