Question about Tools & Hardware - Others
Drive pin gets stuck when firing - Tools & Hardware - Others
    Master:
  • 354 Answers
There is blockage in the path ,take out slide and you'll see there is something there
Posted on Apr 06, 2011
Mod 110 270 when i pull bolt back and load round push bolt forward round fires ?
Gunsmith call, Firing pin is sticking in the bolt or sear is worn.
Jan 19, 2017 | Cars & Trucks
Mossberg 500 A old style firing pin; can I replace it with the new factory pin without changing bolts
It'll work but you'll need the spring, too. The old style pin was pushed back out of battery by the locking lug as you pumped the gun. It won't push the new style so you could theoretically have a stuck firing pin fire a shell out of battery. Be safe, just use the firing pin for your bolt....or buy a new bolt off of Ebay. The entire bolt is a direct switch out.
Jul 30, 2016 | Mossberg Optics
Why doesn't the trigger do anything on my NS289000 framing nailer?
Nailer not firing is caused by lack of lubrication in the headvalve (lube with white grease) or driver stuck/bent (make sure driver moves freely) or safety foot not depressing the firing pin on the trigger valve all the way in. Easy to check. Remove the trigger to expose the firing pin. With no nails in gun, connect air and depress the firing pin with finger all the way in. If the gun fires, adjust the safety foot. If the gun does not fire, lube headvalve and check driver piston stuck. Good luck
Dec 03, 2013 | Campbell Hausfeld Ns2890 Framing Nailer...
Bostitch F28ww nail gun does not cycle. There is no air leak or any sound when I press the nose down and pull the trigger. It is like it has no air at all. I was using it, it fired 2 nails at the same...
It sounds like your drive pin is jammed in the barrel. Can you see that moving freely? One of the two nails it fired may have lost a piece and is jammed in the barrel between the drive pin and barrel.
If this is the problem, You'll need to take a sturdy "drift pin punch" and hammer to drive the drive pin back down into the nailer. (I use an old drive pin from a discarded nailer as a drift pin punch)
Once the piston and drive pin are free again, the nailer should work fine.
Oct 29, 2013 | Hitachi NR83A2 2" To 3 1/4" Full Head...
I have a hitachi nr90ae that will not fire. Depress nose and trigger and gets nothing. What's next?
Remove nails and air supply. Firmly depress safety foot against work with trigger depressed and make sure that firing pin is pushed all the way in. If firing pin is being activated by safety foot most likely problem is stuck cylinder or head valve. If the gun has been dropped the cylinder my jam. Remove the head and make sure that the cylinder and or headvalve moves and that the driver is not stuck in place. Good luck
Mar 07, 2013 | Dewalt Tools & Hardware - Others
How to unjam a paslode f350s nailgun
I use an old driver blade of same model (or close fit). However I grind the back side of the old driver to allow for the metal wedged in the nose. Hold old driver steady with vicegrips. You will need to use large brass or copper hammer (prevent metal splinter ) and strike direct blow so not to break anything (miss and hit gun). Remove the head and cylinder so that you can place the body of the gun against plywood. Place the plywood on concrete floor or solid workbench. May take several hard blows. If you try to use too soft metal to drive down the stuck blade, you risk wedging more metal and making repair impossible for service center. Good luck with your repair.
Sep 14, 2012 | Air Tools & Compressors
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
Can anyone help. ive got a hilti dx450 that won't fire, ive stripped it down and given it a good clean but still no luck getting it to work. could anyone tell me if there should be some sort of firing...
You are correct on the firing pin. Those rim fire caps have to be struck by a firing pin or it won't fire. Pull the head apart and see is the firing pin stuck or missing.
Oct 03, 2017 | Cars & Trucks
The gun got jamned I unjamned the nails but the fireing pin is stuck in the out position
If the firing pin is stuck in the out position, simply take a nail punch or something like it and tap it back in. Oil the gun afterwords.
Jan 10, 2011 | Arrow Tools & Hardware - Others
Powder actuated tool wont fire. I think the firing pin is stuck
is this the one you hit with a hammer? if so check to see if the firing pin is hitting the shell rim at all, if it is sometimes you just have to hit it harder, and make sure your holding the shell in position with down pressure on the handle. if it is the gun model then make sure that the safety lever is is reaching the trip mechanism when you are holding it down making ready to fire.
Feb 05, 2009 | Remington Powder Actuated To Power Load...
Tools & Hardware - Others Logo
41 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
