Question about Cnet Wireless-G CAR-854 Router (CAR854)
Hi I have been trying to configure port forwarding on a CNET CAR 854 router to allow VNC and FTP access from the WAN without any success. I currently have an active DYNDNS account that is synced with the WAN side IP of the router and both the VNC and FTP applications have been configured correctly. We tested this assumption by plugging in a preconfigured Billion router and then tried to access both VNC and FTP over the WAN with success. I have made sure that the port forward rules on the CNET point to the correct ports (Public & Local) as well as the correct IP of the server in question. Using the port testing application from portforward.com shows that both 5900 (VNC) and 21 (FTP) ports are open and that communication is possible. When launching VNC I get an error, 10061 VNC cannot connect to host: connection refused. I also get something similar when trying to connect to the FTP server over the WAN. Regards Chris Pienaar
sandrew
  • 2961 Answers
SOURCE: cnet CWR-854 does not work
You may be advised to use an RJ45 LAN cable to try the following, then use the wireless connection when all ais up and running. The default Login ID and Password is ?root? with password ?1234?. This Wireless Access Point?s default IP address is 192.168.1.253, You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point?s panel for more than 10 seconds to reset its default settings back to factory default. If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
Posted on May 25, 2007
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Posted on Aug 10, 2008
SOURCE: saving port forwarding configuration
To make the change permanent, click Tools and select System commands,
on the system commands click save all.
Posted on Jan 05, 2009
  • 3 Answers
SOURCE: I want to connect cnet cwr 854 as an Access point AP,
ENABLE YOUR WDS ENTER THE MAC ADRESS CIENT
Posted on Feb 06, 2009
  • 34 Answers
SOURCE: looking for default IP adress for my cnet car 854
1. Connect your router to your computer via ethernet cable
2. Now we will check the IP Address
Windows XP
1. Click "Start"
2. Click "Run"
3. Type "cmd" without quotes
4. On the black screen type "ipconfig" without quotes
5. Look for the default gateway, whatever IP Address you can see there is the default IP Address of your router
Windows Vista
1. Click "Pearl button" (Start button in XP)
2. Click "Start Search"
5. Right click the black icon up at the top of the window
6. Click on "Run as administrator"
7. Click on "Continue"
8. On the black screen type "ipconfig" without quotes
9. Look for the default gateway, whatever IP Address you can see there is the default IP Address of your router
I hope this helps you.
Posted on Jan 06, 2010
I need to connect to my work PC from my home, i try to use VNC & remote desktop but I can't configure it right, Any advice?
Make sure that you have a rule in your software firewall to allow VNC through.
You also need to make sure that your routers firewall has the correct ports forwarded.
Can I suggest you try TeamViewer
Its Free for personal use, you need a license for business
Its probably the most powerfull remote software around
Its a lot easier to use and has much more features than VNC
Goodluck
Please rate
Apr 14, 2011 | Computers & Internet
Trying to access 192.168.1.254 for siemens se567, followed advice to go to run and cmd ping, don't understand other go to access point, my situation is the older couple I live with have wirless internet in...
The internet connection has a security that's why you can't access the internet. The only thing you have to do is to know the wpa password of the router.
This router has a default username and password to configure all the settings. This is the manual for Cnet CWR-854 Router:
http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20User%20Guide.pdf
It seems that the router is already configured by an authorized person, the best thing you should do is contact the authorized person that knows everything about the router.
Jan 25, 2010 | Cnet CWR-854 Router
How will i do port forward settings ?
Your router model is CWR-854, I suppose.
Port forwarding instruction for your Cnet Wireless CNET CWR-854 Router can be found here. Choose the program for which you want the port to be forwarded or use the Default Guide.
Oct 25, 2009 | Cnet Wireless-G CAR-854 Router (CAR854)
How to enable WAN IP in a DI-604 Router for 3 computers
"I wanna make the 2nd pc a server but it isn't accessible through the WAN ip. "
Well that explains everything. If you want to get to 192.168.0.102 from the internet, you need to tell the router where to send packets. You do this by going to the ADVANCED section and configuring Virtual Servers. For example: If you are setting up the computer at 102 as a ftp server, ftp uses port 21. The name would be FTP, private IP would be 192.168.0.102, Protocol is TCP, and the Private and Public ports would normally both be 21. Don't forget to Enable the rule.
What this does is tell the router that when ever a request comes in on port 21, it should forward it to 192.168.0.102. To access the external side of the router you need to go to 70.55.84.233 (according to the image you posted)
Jan 03, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Cnet CWR 854 Router
Try this another way of resetting the router, Press and hold teh reset button for 30 seconds while the power is ON then after 0 seconds unplug the power of the router for 10 seconds , then check again if the lights WAN and WLAN lights are still OFF, if its still OFF you can try calling this number for further assistance for this router 1-877-787-8749 so atechnician can walk you through in checking if this router si really bad already or still can be fix....
Oct 16, 2008 | Cnet CWR-854 Router
Saving port forwarding configuration
Aug 26, 2008 | Cnet Wireless-G CAR-854 Router (CAR854)
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
Ftp - port forwarding
Hello.. If you already have the port numbers needed and static IP on your computer, you can do the following steps to open them on your router:
1. connect a computer to the router wired.
2. Launch an internet browser and type in http://192.168.2.1. Use the user name and password that you have set for your router.
3. Click on the Firewall tab, then Port Forwarding
4. For the Protocol, specify if the port you will open is TCP or UDP.
5. Set the port numbers on both WAN and LAN port range then set the Static IP address on the textbox then click add. After doing that, check if you have an apply,save or ok button and click on that.
Here is the site for the user guide of your router.
If you do not know how to set a static IP on the computer, you can do the steps from this link. This depends on the operating system of the computer you are using. Make sure to set an IP address in the range of 192.168.2.x (x being a number from 2- 200).
Jul 30, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Ftp server
What is the name of the software? Is that an FTP software?
Anyway if you are using DX-E401 Router you can enable DMZ (demilitarized zone) to your PC.
1.access your router configuration page (default ip: 192.168.0.1)
2.go to advanced tab
3.select DMZ
4.select enable then type the ip address of your server pc
5.apply settings
after that have someone try to access the files in your pc.
if the software you installed is ftp software then have them access it by this
ftp://internet_ip
the "internet ip" is the ip address found in the STATUS TAB of your router under the WAN catergory.
If this software you mentioned is using any particular application ports, you will have to open those ports for your server PC.
In that case you will to configure VIRTUAL SERVER. It's the actual term used by dynex. for you to have a general idea how to configure your pc behind your router please go to this link
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Manual.pdf
Virtual server configuration is in pages 22-23. It has detailed explanation of the terms used.
Hope this helps!
May 07, 2008 | Dynex DX-E401 Router
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Aug 09, 2007 | SonicWALL PRO 300 Firewall
Cnet Wireless-G CAR-854 Router (CAR854) Logo
61 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
ddalecki
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
