Question about Conair Health & Beauty
PUTTING BACK THE TRIMMER
Hello I need to put back a trimmer GMT171 Cordless. I removed the trimmer and attached the nose trimmer. But now I want to put the beard trimmer back on and its not going on well. Help.
    New Friend:
Just need manual does anyone have it for this model GMT171
Posted on Nov 26, 2012
4 Suggested Answers
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Posted on Jan 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: changing trimmer heads on Conair Beard Trimmer - Model GMT188
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
SOURCE: How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Posted on Dec 24, 2010
How to replace battery on a black and decker cordless trimmer
  • Remove battery pack
  • Unscrew screws with Philips #2 to remove cover plate
  • Suggest you take picture with smartphone / digital camera of layout before removing battery, so you can easily pit back correct
  • Remove battery - you can easily get a replacement at Batteries & Bulbs or online.
  • Replace battery
  • Reassemble per picture
  • Put cover back on
  • You should be good to go
Jun 04, 2014 | Black & Decker Cst2000 12 - Volt Cordless...
Switch accessories on the wahl 9876l
Cradle the trimmer in your hand, and use your thumb to push the blade assembly out / away from the trimmer. To install any of the attachments, hook the white nylon hook on the blade assembly into the notch on the bottom of the trimmer, and snap the blade into the trimmer.
Apr 07, 2012 | Wahl Health & Beauty
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
Yardworks cordless grass Trimmer / Edger How do you remove old spool and replace with new one.
To remove old spool just unscrew the center screw on the blade. Push out with force and put new one in place, afterwards screw back.
Thanks,
Jul 06, 2011 | Garden
My Black and decker cordless trimmer is not quite out of juice but it is not cutting anymore. can i recharge it now or do i have to wait until the battery is completely dead?
You can recharge the battery at any time. I usuly use mine then when done using it I put it back on the charger so I know it will be charged the next time I need it.
Jun 19, 2011 | Black & Decker String Trimmer Cordless 12"...
I have a Conair GMT189CGB 13 piece styling trimmer how do I change the nose/ear trimmer? I have no idea how it snaps in? what a terrible design!
You do not need to unscrew anything. Instead, simply take the beard trimmer (with the beard shaving blade still screwed on) in your hand, with the power button and "CONAIR" logo facing you. Then, put your thumb under the shaving blade and apply force to pop it off. So, the shaving blade, and the top part of the unit that it's screwed into will simply pop off. Then, you simply align the nose/ear hair attachment, and snap it in to the beard trimmer unit.
Jan 16, 2011 | Conair GMT 170 CS Beard Trimmer
I have a 25cc homelite weed trimmer.... the fuel line is loose in the fuel tank... how do i get it back in
You will need the correct size fuel line first. Follow this:
1. Remove the old filter/weight from the fuel tank.
2. Take a new fuel line piece about 8 inches long and cut about a 45 degree angle cut on one end.
3. Lightly moisten the cut end of the fuel line and insert it into the tank from the outside, pushing it in while turning as far as possible.
4. Use a needle nose plyers to reach in and pull the line to the fuel line cap. Cut the line and replace the filter.
5. Pull the line back the way you put it in leaving about 4 inches within the tank and re-attach to the carburetor or primer bulb (depending on the actual model/age)
It will work, but it is extreemly important to have the correct size fuel line to work with.
Sep 27, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
How do I attach the machine to the wall charger when the protective cover prevents it fitting properly to the wall. Sticks out below putting it at an angle to not fit into the charger. Do I have to remove...
If you can't make the charger fit while the battery is attached to the trimmer, you can remove the battery pack (the whole black handle assembly) by pressing in the two orange tabs (one on each side) and sliding the battery pack forward off of the trimmer. Then you can plug the charger in and charge the battery wherever you want. It can be a struggle to remove the battery pack, but it does come off.
Hope that helps.
Jul 17, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
May 29, 2009 | Worx GT WG150 10 in. 18 Volt Cordless...
Health & Beauty Logo
386 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
