Question about Zanussi Washing Machines
Zanussi turbodry 1200 wje 1207 error code 40, i believe there is something with the door. now the whole system is shut down. what to do.
2 Suggested Answers
  • 17 Answers
SOURCE: What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Posted on Dec 17, 2008
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanusssi jetsystem turbodry 1200
clean out filter, door bottom right, unscrew filter and clean it
Aug 02, 2008 | Zanussi IZ161S Front Load Washer
Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 08, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem Turbodry 1200
replace the circuit board
Feb 19, 2008 | Washing Machines
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
228 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
