Question about AMD Athlon XP 1500+ , 1.33 GHz Processor
Can make and SDRAM and DDRAM? works with both statements at once?
  • 120 Answers
NO. IT WILL NOT WORK
Posted on May 26, 2011
I have asrock p4i45 can i put ddr3 or ddr2 2gb ram
hello rkr phoenix, u can only use DDR2 on this motherboard, this was type motherboard with processor socket 478, and this type only have two choice, SDRAM or DDRAM, on asrock p4i45 can have DDRAM socket. hope this useful, regards.
Aug 22, 2011 | Computers & Internet
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
I got a computer handed to me with a asus P2B-f motherboard, works well, but running win98, may upgrade right away HOWEVER very slow with 128MB SDram win98 wont allow for the flash/adobe required to run...
Here is the manual for that board:
http://www.csslabs.com/static/download/cds/112/Mobo/ASUS_P2B-BX/Manual/Mb-p2bf.pdf
You must use 3.3 Volt unbuffered 168 pin SDRAM. Each slot (total of 4 slots) can have up to 256MB for a total of 1 GB.
Most local used computer shops will have this kind of memory (used, of course), probably at $10 or $20 a stick.
This memory is also available new (just don't buy anything over 256 MB per stick):
http://www.compusa.com/applications/category/category_slc.asp?CatId=145&name=SDRAM&
You can use PC100 or PC 133. You can also use ECC or non-ECC. Non-ECC is more common.
Aug 16, 2010 | Computers & Internet
How do you "turn on" or make newly installed memory work on a laptop computer
upon boot-up the system automatically detects the amount of memory installed, if for some reason the amount of memory installed it's not the same with the amount detected there might be a problem with the placement of the modules or the system simply does not support either the module, quantity or type of memory. (if you're talking about system memory eg. SDRAM/DDRAM).
May 25, 2010 | Dell LATTITUE C- SERIES FDD MODULE 1.44MB...
What steps are needed to upgrade my memory. I have a etower667ir with ramsd64mpc. I want to install 2 128mb sdram dimm pc100. what do I need to do?
First download a system analyzer fromwww.belarc.com and use it to check what is the maximum Ram that it can accommodate. If it will take just make sure you-get Non-parity ram when you buy the sticks. please note that SDram is more expensive that DDRam, but cannot be substituted.
Jan 06, 2010 | E-Machines etower 667ir PC Desktop
How to jumpe SDRAM to DDRAM
according to my research- this mobo will support 2GB ddr400/333 sdram- 1GB in each slot. don't think it will support ddram. don't know if you can mix 400 and 333 bus speeds. probably can, but put 400 in slot 1. not sure ddram will even fit in ram slots!
good luck!
Sep 24, 2009 | EliteGroup nForce3-A Motherboard
Problem for ecs m810d
it's between ddram n sdram connector.
Apr 03, 2009 | PC Chips M810DLU (M810DLUV75C) Motherboard
Diff between SDRAM and DDRAM
Only one of those will work in any computer. Synchronous Dynamic Random Access Memory is older and slower, Double Density Random Access Memory is faster and DDR2 is newer. The notch in the connector edge will not match the RAM slot if you have the wrong one. Also the DDRAM has various speeds to match the bus speed of the motherboard so designators like PC2100, PC2700, PC3200, etc. are important and correspond to 266MHZ, 366MHZ, 400MHZ, and so on. Notebook use SODIMM RAM and have the corresponding DDR, DDR2 designators but still have notches that must match the slot. When you buy RAM just provide the model of your computer as each manufacturer has numbers that are all designed to confuse it seems and there may be no chance of exchanging the memory after you open the package. Steve
Oct 14, 2008 | Compaq Presario 700 470024-192 Notebook
AMD Athlon XP 1500+ , 1.33 GHz Processor Logo
18 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
